s50+zf tranny shifter linkage rebuild parts...
  • AirplaneBuilder
    • 823
    I'll be dropping my s50 and zf tranny soon and wanted to rebuild my shifter linkage to get rid of extra play and slop. I cant find a diagram that shows the entire assembly and lists all the part numbers, rebuild kits that are 150-200 seem a bit pricey so i just want to replace a few parts to stay within the $50 range. Anyone know a website that shows the diagram with all part numbers or can recommend me what are the most critical parts to replace? Swap parts have 118k on them. Any help would be nice
    1989 Zinno 325i S50 ZF320
  • SwiftE30
    • Jun 2010
    • 998
    I'm pretty sure this is exactly what you are looking for.
    http://realoem.com/bmw/showparts.do?...13&hg=25&fg=05
    and check out some threads on shift linkage because some people prefer to use a combo of e30 linkace and e36 carriers, and visa versa. I'm using full zf carrier and linkage and its a little sloppy so im at the same point you are. Im thinking about going with a UUC DSSR, but its a little pricey.
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
    • 328ijunkie
      • May 2007
      • 3961
      Everyone forgets to replace the foam 'bushing' on the shift rod on the trans. dont forget that one.
      Check Us out on Facebook
      Full Product Line Tuning
      • AirplaneBuilder
        • 823
        Thanks man! exactly what i needed, i've seen this diagram several times in my search but never with the part that had the part numbers! You have an s52 turbo!! After i finish my swap we should come out to a weekly meet so i can get some inspiration by your car, i have a feeling a plain NA s50 will get boring fast haha.
        • SwiftE30
          • Jun 2010
          • 998
          Yeah no problem man, i actually had to find the part numbers from this diagram and buy a few things like 4 days ago so nice timing.
          And dang, didnt realize your just up in lynwood. We should definitely try and meet up and talk shop and show off our rides when i get back from school. As it sits right now, my car is still NA, but im working on getting my megasquirt system figured out right now so it'll be ready to go, shortly after i get back from school.
          I was going to stay NA, but after mulling it over I simply realized a Forced Induction swapped e30 would just be the shit. So i went for it. I think you should do the same.
          • SwiftE30
            • Jun 2010
            • 998
            I made a point to keep this part along with the clip that holds it to the transmission, but unfortunately my brother made his way into my shop and made it look like a tornado went through there and lost both. So i just ordered new ones.
            Did you heat and bend your shift carrier to account for the 15 degree change on the m3 linkage? its kind of bugging me right now and would like to fix it. Its not liking 2nd... or 5th :(
            • lbreevesii
              • Aug 2009
              • 412
              tru dat. it makes a difference.
              I don't always wreck cars, but when I do I wreck them into trees.
              91' 318is S50 swap - The Black Widow
              • Supadave
                • 1006
                Bam http://www.r3vlimited.com/board/showthread.php?t=41971
                https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
