1986 325e M50B25: Relays not powering on
May have found this thread too late. I am getting no power to the fuel pump relay terminal 30. Also have a red wire from the e36 harness that is labeled fuse power but i already have power to the fuses or at least most fuses(not sure if all would be active).97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
83 733i 5 speed, (FS)Comment
There's the fuse box that goes to positive, then their is a big wire and I think two littler wires from the E36 harness that get positive. There's really only the one wire that's close to the DIAG connector and the engine ground that get grounded.Comment
^^This is what you should go off of.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IPComment
Are your fuses blown?Comment
Sorry to revive an older thread--OP, what did you figure out about this?
I had the EXACT same problem when I tried to fire my swap last night. I was also under the impression that key "on" was supposed to close the relay. I also jumped it manually and got fuel spewing out of the rail. I didn't get a chance to take a good look at it, but I figured that I had electrical problems coupled with a REALLY bad o-ring or maybe hole in the rail...
From reading this -- could our jumping the relay without cranking the motor cause a pressure build up and leak? or do I actually have a bad O-ring :S
Also, how did you get your relay to work? was it related to the Main (DME) relay or the DME itself at all?
Sorry, I hate troubleshooting electrical but since we seem to have had the exact same problem figure I'd revive this threadComment
Hey guys i'm having this same problem. What was the solution you guys had?Comment
My problem was just a missing ground. Checked over everything and added an additional ground strap and it was good to go.
Sent from my GT-N7105 using Tapatalk 4Comment
No power to main relay folks-
Follow what FF said, peel back the black heat shrink and look at wire colors.
You should have the original E30 cable for you starter and fuse box power.
Use the power block to power the red eyelet on the e36 harness conveniently located on the battery tray. Ground eyelet goes to strut tower ( or any body ground if using M3 firewall covers).
power wire from alternator goes on starter and be sure you swap the ground swap from drivers side to pass side so you have cranking.
Use a test light or meter to verify you have power where you need it! No check engine light with key in position 2 means dme no power on.
On my first swap I had no power to DME relay, traced wire all the way to dist block, I had the red eyelet on the MOUNT stud of the dist block, no 12v+ there lol.Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.Comment
I made the same mistake with the putting the red power on the dist block. Thanks for mentioning it as you saved me a ton of time!Comment
