c101 and x20 wire function questions....90% finished cant find rest in the ETM
  • 86325LSD
    • Aug 2004
    • 296
    any help where you see ones that arent labeled would be most helpful or if some are labeled wrong. I have some concerns about the x20 becasue it seemedeverythin lead to "DataLink" but i know that it doesnt necesarrily mean ir didnt serve another function as well. Any input here would be great. These are both Body side plugs. c101 from a 1991 318is 5spd, and x20 from a 1992 325i coupe 5spd.
    Thanks.
    faint in, throttle out.
  • cabin
    • Dec 2006
    • 552
    This is what I have on my wiring chart,
    E30 Side
    6- O2 Heater
    7- DME
    8- Fuel Econ. signal
    9- Engine Speed signal (tach)
    11- Service Reset
    12- CEL
    14- Speedo Signal
    E36
    10- not needed
    11- not needed
    12- Water Temp
    23- oil pressure
    -Justin
    Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
    • 86325LSD
      • Aug 2004
      • 296
      thanks dude I'll give it a try.
      • 86325LSD
        • Aug 2004
        • 296
        question though if 23 is oil pressure. what is the "pressure switch" @ pin 5 on the e36 side
          • 34844
          318is is the same as a '90 325i, without an oil level sensor.
          • 86325LSD
            • Aug 2004
            • 296
            so i have used the information above in conjunction with the image below to create my entire harness and have every wire from the c101 connected to something (hopefully all correct) except for the Gr/Yl pin 6 connection that is apparently O2 Heater or Power and the ABS red yellow wire? What wire should this connect too on the x20. I'm assuming pin22 or pin 10 as they are the only remaining wires of that gauge. Please help me out, and lastly where is the common spot to steal +12V for the red yellow ABS wire.
            Thanks
              • 34844
              for pin 20 (ABS power) just run a wire from pin 6. No need to splice into anything.
              • 86325LSD
                • Aug 2004
                • 296
                awesome pin 6 pin 20 c101 to pin 22 of x20 . dual purpose.
                  • 34844
                  yep!
                  • 86325LSD
                    • Aug 2004
                    • 296
                    some pics for fun of the progress. Special thanks to my friend for soldering. I hate that shit.
                    still slightly incomplete. Will take a pic of the complete diagram tonight.
                    • 86325LSD
                      • Aug 2004
                      • 296
                      finished wiring diagram... Will be test running it tommorow and let everyone know if it works.
                      • lolcantturn
                        • 4588
                        I live in Bayonne...if you want me to stop by I can and I'll get your car running easily. Done too many of these swaps.....
                        Originally posted by TSI
                        OEM+
                        • 86325LSD
                          • Aug 2004
                          • 296
                          If it doesn't go for me tomorrow I may do that, but at first glance how do my charts look?
                          Do i have the right functions at the right pins?
                          • 86325LSD
                            • Aug 2004
                            • 296
                            CEL isnt on and the m*%^$# f(*&%% just cranks and cranks away.
                            It will not start and I'm fed up.
                            • e30rapidic
                              • 2167
                              maybe I'm having a brain fart but why are you cutting the wires going into the C101 from the right hand side in this picture???
                              are you splicing the X20 in here rather than modify the engine harness??
                              try this link, scroll down to the bottom of the page. Hope this helps...
                              http://www.rmeuropean.com/bmw-e30-m50-swap.aspx
                              '87 325ic, powered by S50.
