m50TU Cam options
  • sofa KING euro
    • Nov 2011
    • 414
    m50TU Cam options
    I just swapped an e34 M50TU into my 90 e30 chasis and I wanna pull a little more power out of her, the best looking option right now seems to be head work/cams. Since Im new to the e30 scene I'm wondering what my options are as far as swapping a s50 head onto my m50 or just using the m3 cams. Also, I came across schrick cams for the m50 that I was considering but does anyone know if I'm going to have to upgrade valve springs/keepers, seats, etc?
  • sofa KING euro
    • Nov 2011
    • 414
    bump
    • MaxBell
      • 1391
      As far as I am aware, S50 cams are an upgrade, as are Schrick (which are close, if not the same as S50 cams).
      I've seen S52 cams get swapped in, with the carrier, but I don't know too much about that.
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
      • sofa KING euro
        • Nov 2011
        • 414
        Thanks so can the head from the s50 be swapped in?
        • JJe30
          • 2044
          s50 cams will go right into the m50tu. I did this with larger injectors (pink top 19lbs), chip and 3.5 HFM. I dyno'd about 196/175 with my tune leaning out just after 6250. I was quite impressed with how all that helped open up that motor.
          • sofa KING euro
            • Nov 2011
            • 414
            Sweet! thats something I have to look into! Now when you swap the s50 cams is anything else necessary like valve springs or seats etc or is it just cam swap? And what chip did you use because Ive been looking can't find one for m50 with s50 cams....thanks for your input!
            • dude8383
              • Jan 2005
              • 10387
              Just straight cam swap. It all depends on you if you'd like to get new valve springs etc... you'll have to pull the head to do all of that and then the whole "wellllll while i'm in there" mentality sets in. From there its just a slippery slope. I speak from experience. LOL.
              http://www.racersmarket.net/ - for your chip needs
              OR
              http://www.dsylva-tech.ca/ - i think he can do a custom tune that'll be great too
              • sofa KING euro
                • Nov 2011
                • 414
                thanks man big help!!!
                • e30gentry
                  • 608
                  I have some S52 cams, trays, lifters and springs let me know if your interested. I have a for sale add with them and PM for pictures.
                  • sofa KING euro
                    • Nov 2011
                    • 414
                    Has anyone swapped the s52 cams and carrier into an m50TU head? wanna know what im getting into here
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      You need the matching trays if you do.
                      Originally posted by 325Projectz
                      don't listen to the diagram... listen to mr. swiss.
                      :nice:
                      • dnick
                        • Apr 2011
                        • 1377
                        Id just do the s50 cams and shit.. make it easy on yourself!
                        BTW.. just noticed your from cleveland.. ill be going up there at some point this spring to visit a friend!
                        • sofa KING euro
                          • Nov 2011
                          • 414
                          yeah? we should meet up at one of the local meets
                          • dnick
                            • Apr 2011
                            • 1377
                            hows the e30 scene up there?
                            • sofa KING euro
                              • Nov 2011
                              • 414
                              lol not really sure just got mine not too long ago but ive seen a few around
