M50 w/ 4.10 16.5mpg highway-normal?
    I remember my old swap with a 3.73 getting 26mpg with an M50 @ 70mph indicated
    With a 4.10 my current M50 is getting 16.5mpg @ 65mph indicated.
    Is this normal ? I have a new O2 in there (but I do get the O2 heater relay code sometimes).
    Originally posted by TSI
    OEM+
    I got about 22 or 23 mpg with my 4.10LSD and m50
      I was around 22-25 with 4.10 gears on my old car.
        jesus christ my car sucks
        OEM+
          what trans are you running?
            Getrag 240.
            There's nothing I can even conclude as to why my mpg sucks either. EVERY maintaince item is up to date..like <1000 miles. fuel filter, plugs, O2, FPR, everything.
            OEM+
              yep, its all about RPMs. if you slow down the motor, you will get better mileage.
              I was getting about 22-23 with 4.10, G260 and M50TU before I swapped it around.
              I am now averaging 24-25 with 2.93, ZF320 and M50TU. rpm at an indicated 80mph is a shade over 3k
              I saved 15% on my Bimmer parts by switching to ...
                dont base it on your gauge.
                I just do my ODO, and divide by tank size
                  I use ODO miles and divide by gallons added to fill. sometimes I refill before the light comes on, but not very often......
                    yea, Im am averaging 26-27 mp with m50 :)
                    2.79 diff
                      21mpg avg mixed driving
                      s50 getrag240 4.10 LSD
                      Originally posted by FredK
                      However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
                      My year in Germany
                      Feedback
                        Depends on how you drive, traffic conditions, altitude, Tires-width and height and compound as well as condition of engine.
                        TU or non TU? Too many unknowns. Your life always seems like a soap opera.
                          I have the same problem as him, 4.10lsd with an m50nv full refreshed and a g240 and I average 15mpg, and that's not using the gauge, ODO/gallons method.
                          Originally posted by Wh33lhop
                          VANOS: sometimes you just need to go full retard.
                            I drive like an old man. Seriously. In the city my RPMs never go past 3k. On the highway I only see past 70mph on a downhill. My tire width and height were the same as the M50 car i was getting 26mpg with. Non vanos
                            And yes my E30 life is plagued with trouble.
                            OEM+
                              well gears ratios per gear in the g240 could also be affecting your mpg. A high fifth gear ratio can yield low mpg
