M50 w/ 4.10 16.5mpg highway-normal?
    I was doing better than that with a 4.10 and a ZF. (I think that might have been the first time I drove the car on the highway.)
    And no, I am not counting the MPG gauge. Although it isn't that, that far off with 17lbs. injectors. Highway MPG was around 19-20. I've generally found that the S50 is not very sensitive to gearing as far as fuel economy goes. Peak fuel economy was 24mpg with a 3.46 and a G260, but that was unbearably slow.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
      Originally posted by sofa KING euro View Post
      well gears ratios per gear in the g240 could also be affecting your mpg. A high fifth gear ratio can yield low mpg
      The G240 is pretty similar in gearing to the g260.
      Originally posted by Wh33lhop
      VANOS: sometimes you just need to go full retard.
        Originally posted by scottinAZ View Post
        yep, its all about RPMs. if you slow down the motor, you will get better mileage.
        I was getting about 22-23 with 4.10, G260 and M50TU before I swapped it around.
        I am now averaging 24-25 with 2.93, ZF320 and M50TU. rpm at an indicated 80mph is a shade over 3k
        Dying to know if theres a solution to be found in this thread.
        I avg 19 and some change mixed with my m52 ZF320 and 2.93.
        I get more or less the same miles per tank (250) as I did when I had the ZF320 and 3.73 :-?
        I usually cruise around 60-65, any faster and I'm
        What am I missing here?
        Originally posted by ebelements
        Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
          I have the same set up as you and my MPG's are also painfully terrible. I'm looking for a 2.93 to hopefully help me out. 3000 RPM at 65 MPH is killing me.
            Jeez. Yalls MPGs suck.
            Check Us out on Facebook
            Full Product Line Tuning
              27.3 MPG this tank ;)
                Just calculated my mpg the other day.. currently getting 12mpg :???:
                m50tu with g260 and 3.73 diff..
                Calculated by my daily commute of 50 miles round trip and the consumption of damn near a quarter tank... Heavy on the foot, missing an o2 sensor (installing one this friday), and half my commute is city driving.. All adds up :(
                Going to probably get a 2.93 diff in the near future.
