Yeah, with more modification, a different master cylinder (one more thing to buy), and you have to run lines and remotely locate your reservoir somewhere else.
The reason people feel like the E21 booster is "inadequate" is because it is. It's a smaller diameter and the same thickness as the stock E30 booster. The 944 booster is a smaller diameter, but is thicker, and has almost the same internal volume as the stock E30 booster. Uses the stock E30 master and reservoir, too. All you do is shorten and thread the pushrod, then it's a direct fit.
