M50 W/ ZF Transmission
  • Robert
    • Dec 2010
    • 3770
    How far does the pedal need to be pushed down for the clutch to be engaged?
    I push my pedal down ALL the way to the fire wall, and it will engage about a half inch from the firewall , its a pita to drive. Any Ideas how I can get this fixed?
  • bernzpeed
    • 3917
    clutch slipping?
    89 E30 S52
    Transaction Feedback.
    • Robert
      • Dec 2010
      • 3770
      Originally posted by bernzpeed
      clutch slipping?
      It's not slipping , just engages really low.
      • butters
        • 1202
        bleed it. then bleed it again.
        • SwiftE30
          • Jun 2010
          • 998
          ^^this. I had two people help me; one making sure that the reservoir stayed full, one person checking the bleeder screw, and one continually pushing the pedal. MAKE SURE THE RES STAYES FULL. then bleed it, bleed it, bleed it. then do it again.
          and check your lines.
          1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
          • Robert
            • Dec 2010
            • 3770
            Okay. I will have a shop bleed it. My bleeding wasn't good enough. We used a power bleeder, still wasn't good. After using the power bleeder it gained some pressure, we tried to do it the old school way and it lost pressure right away.
            • WADE30
              • 249
              I have an M50 with ZF and this man speaks the truth.
              After three years of driving it even now I had to remove my elevator bolt because it was shifting like shit because it started engaging lower.
              Just bleed it bleed it.
              • SwiftE30
                • Jun 2010
                • 998
                what sucks is the bleeder screw is such a pain in the ass to get to and work with. took me forever, and I ended up with cargasm fluid on my face .
                • nrubenstein
                  • 3148
                  id you install the throwout bearing correctly? Flat sides top and bottom. Doing that wrong will meaningfully lower the engagement point.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                    • 37829
                    Robert, definitely bleed it again. If you don't go to JMP or Castros just talk to Shant.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
