Quick n00b question about the throttle cable
  • egye30
    • Jun 2011
    • 100
    so ive been doing research and i read that the e36 (328is in my case) throttle cable would work, can anyone confirm that?? since i've got a donor already. and if not, then it needs to be the e34 m50 cable, right? Anybody know that part number for it?
    thanks for the help
    1990 325i Sterling Silver Metallic/Black leather.
    M52B28 OBD-I W/ S52 Cams, M50 Manifold, SS Headers, Kamotors CAI, Stage 2 clutch w/ 14lb flywheel, Mark D chip tune.
    Bilstein Sports with H&R Race + E90 drop hats, F+R Strut bars, '04 330ci Steering rack (3.0 Lock to lock, 13:1), 3.15 Z3 torsen LSD
    Custom Built BBS RS's 16x8 square.
    RESPECT YOUR ELDERS. Decals for Sale!
  • Danny
    • 14216
    I use the stock e30 one every time.
    • egye30
      • Jun 2011
      • 100
      What modifications need to be made to it?
      • 328ijunkie
        • May 2007
        • 3961
        Stock E30 one will work but look/work like shit. E34 M50.
        Check Us out on Facebook
        Full Product Line Tuning
        • scottinAZ
          • Dec 2009
          • 1312
          +1. the engine side of the stock cable uses a different mounting setup than the M50. E34 cable is a direct fit for the M/S5x series engines.
          I saved 15% on my Bimmer parts by switching to ...
          • hwy84
            • Aug 2009
            • 190
            +2 - E34 M50 is nice and clean.
            Current:
            1991 325i Sedan - S50 Swap
            1988 325i Cabrio
            Past:
            1991 M3
            1991 318is
            1985 325e
            • blackhawkimpact
              • 2415
              How does it look like shit? Idk if the m20 cable is different but I have the m42 cable and it looks good and works like a champ
              • Danny
                • 14216
                I don't know what you guys are talking about, my cable works excellently.
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  This, m42 cable here.
                  Originally posted by Wh33lhop
                  VANOS: sometimes you just need to go full retard.
                  • egye30
                    • Jun 2011
                    • 100
                    So the m52 cable from my donor won't work then?
                    • ScHpAnKy
                      • 1573
                      anybody got pics of their setup?
                      91 318i | 87 535iS
