M50 3.0L stroker, who's done it?
  • FreedS4
    • 752
    Trying to get an idea of who's actually done the 3.0L stroker on an M50. I've seen a few threads (yes, I searched) with people talking about the stroker, but haven't seen any build threads. Thanks in advance.
    Chris
    • 37833
    It's called an S50. ;)
    Grover Beach, California
    BimmerHeads.com
    • lifeiskaos
      • 1709
      I have, what do you want to know?
      • FredK
        • 14762
        haha... I think he means the 89.6mmx84.0mm stroker with an M54 3.0L or S52 crank?
        • unloadedak
          • 1197
          my buddy has one.
          2003.5 Imolarot M3: daily
          1995 Alpinweiß M3: hpde
          • FreedS4
            • 752
            You so funny!
            What're your thoughts on it?
            Would you do it again?
            Did you replace your main bearing bolts?
            What head gasket did you use?
            What DME are you using and with what aftermarket chip/tune?
            M50 with M54B30 internals...sorry about that, didn't clarify.
            Originally posted by unloadedak
            Thanks for the link, I'll check it out.
            • brokenbimmer533
              • 317
              Thats me.
              I like it. I completely rebuilt the motor. New rods, low compression pistons. I'm sure Ill like it a lot more when I install a turbo.
              Replaced main bearing bolts and rod bolts, arp is the way to go.
              MLS headgasket.
              I'm running a standalone engine management. MS 2 extra to be more specific. I wanted to be able to tune it for NA for now then tune for forced induction when I add a turbo.
              Any others?
              What are your plans for the motor/car?
              • trackjunkie21
                • Jan 2010
                • 3962
                I'm in the middle of sourcing parts for this as well, what is the end CR ratio reusing the m54 internals? I'm hearing a lot of contradicting numbers.
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                • PiercedE30
                  • Apr 2005
                  • 4220
                  See sig for 2.9L goodness.
                  My 2.9L Build!
                  • Court M3
                    • Jan 2004
                    • 6713
                    Man next time I'm back home, I definitely have to come see this car!
                    Continuous For Sale Thread
                    323i s50
                      • 37833
                      I knowwwww, I knowwwww.
                      BimmerHeads.com
                      • The Humjet
                        • Jun 2010
                        • 528
                        Someone down here has a 3.1 m50.
                        • Pudmunkie
                          • 210
                          I've read between 9.5 and 10.5. Not very helpful I know... let us know what you find... my bottom end is assembled just need to get around to doing the rest... nv m50 block with m54 internals and s52 head/cams
                          Sent from my Transformer TF101 using Tapatalk
                          • FreedS4
                            • 752
                            I read through your whole thread over the last few days. Nicely done!
                            For now, I'm doing a full rebuild, with M54B30 internals and stock everything else. I'll see where that gets me and go from there. I've got a set of Schrick cams that I'll eventually install, but I want to get it running well first, before I go tinkering too much.
                            I've seen the same contradicting numbers, but it's kind of hard to give a definitive answer as everyone's build is slightly different. I haven't run the numbers on my build yet, so I can't give you a good answer on what I'm expecting for CR.
                            • PiercedE30
                              • Apr 2005
                              • 4220
                              Unfortunately, it's no longer with us. Louisiana drivers FTL....
                              My 2.9L Build!
