New s50 swapped car...Few questions.
  • utchia
    • Feb 2012
    • 48
    First, what is normal operating temp for a s50 e30? It always runs about a line after the middle, which normally I would think would be too hott, but the PO said thats normal, is it? It never goes beyond that. The wp and radiator are new, and it also has a switched electric fan, and I do believe the stocker too. Should I be worried?
    Also, when it comes to exhaust, specfically headers and catback, does normal m3 stuff work, or do they need to be shorty headers because of space?
    Any help you can give would be greatly appreciated. I did search, but didnt really find a consensus when it came to the operating temp.
  • e30shmobberr
    • 1934
    I have a full e36 m3 OEM obd1 mid pipe with a uuc corsa catback on my car now. If thats what your meaning my m3 exhaust
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    • cormier
      • 380
      Long headers have trouble clearing the CABs. Shorty are generally used with no modification and custom downpipe
      • gianluca1505
        • Apr 2011
        • 13
        hello guys
        i'm Gianluca , from Italy and I made the same work on my bmw z3. I have only one problem : i don't understand the electric cable of my s50b32 engine. do you understand the maps of circular connettor of that engine ? do you know the number of PIN what are? please can you help me ? ciao gianluca
        • Den_k321
          • 1248
          im finishing up my s50 swap, and i installed Ebay headers, their very long, and they clear everything without any modifications.
          1988 325is S50 in-progress.
          http://www.facebook.com/E30LocalCrew
          Few pictures:
          http://www.r3vlimited.com/board/showthread.php?t=255061
          • mentaleeill
            • 850
            you're judging the coolant temp on the stock gauge? many things could make that in accurate, try installing an accurate aftermarket gauge.
            but if the stock gauge and wiring are infact working properly, yes it's too hot. mine always ran between 1/4 and 1/2, or about 190 degrees.
