S52 swap coolant hose HELP!
  • Songj91
    • May 2011
    • 211
    I need a coolant hose that will work for my swap. I hear I need a hose off a different car to fit snug. Anyone know with hose(s) to use?
  • 5KWattson
    • Apr 2009
    • 809
    what coolant hose are you referring to?
    "God created turbo lag to give V8's a chance" Taylor D.
    • ForcedFirebird
      • Feb 2007
      • 8300
      Depends on the radiator.
      john@m20guru.com
      Links:
      • cormier
        • 380
        Rad hoses?
        • Songj91
          • May 2011
          • 211
          Sorry for wording it retarded. ya radiator hoses are what I meant. I'm using a m42 radiator with built on reservoir.
          • 5KWattson
            • Apr 2009
            • 809
            not sure with the M42 rad but the standard e30 88+ rad all i had to do is trim the lower hose to make the length from t-stat to bend shorter, but it fit with out trimming
            • Songj91
              • May 2011
              • 211
              Ok cool so I can use my old hose. Anyone else use the same?(88+)
              • iceman
                • Jan 2011
                • 149
                ^My friend used the 318 radiator on his S52 and it was kind of cool. It fit really well. But I don't think it is powerful enough for an S52, but I guess if you don't live in Arizona or something.
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  Why wouldn't you use new hoses? Re-using old hoses is just such a bad idea.
                  '89 Alpine S52 with goodies
                  • drumad
                    • Aug 2009
                    • 1700
                    dayco d 70440
                    you'll need two, they are the perfect 90 degree bend and diameter for the m42 rad and alum thermostat housing
                    2008 335i - n54b30
                    1991 318i - m52b28
                    1994 fzj80 - LAND CRUSHER
                    • gianluca1505
                      • Apr 2011
                      • 13
                      hello guys
                      i'm Gianluca , from Italy and I made the same work on my bmw z3. I have only one problem : i don't understand the electric cable of my s50b32 engine. do you understand the maps of circular connettor of that engine ? do you know the number of PIN what are? please can you help me ? ciao gianluca
                      • Den_k321
                        • 1248
                        i already finished my houses im almost finished with s50 swap, and i used m42 radiator.. i can give you a write up and take some pics tomorrow...
                        1988 325is S50 in-progress.
                        http://www.facebook.com/E30LocalCrew
                        Few pictures:
                        http://www.r3vlimited.com/board/showthread.php?t=255061
