e34 powersteering pump 24v swap
  • xwill112x
    • Jan 2009
    • 4237
    Whos done it? is it even possible? I need more info...putting the motor in soon and trying to see if I can use the e34 pump instead of the e36 pump?
  • TimKninja
    • 2131
    I used the E34 pump. No problem at all. The stock e30 lines and banjo bolts from my ETA threaded right in . At first they leaked then they stopped leaking...
    It also felt better then the m20 pump.
    1985 325e M50TU(Sold)
    1991 318is Slicktop (Sold)
    1990 325is Brilliantrot S50/5 Lug Swapped.
    1992 525i Manual shitbox Winter Beater
    • MaksV
      • 1042
      all of this. Get new crush washers and nothing will leak.
      CHEAP REBUILT INJECTORS
      Need Quality Brakes? BimmerBrakes has it!
      For anything Else go with BluntTech!
      • xwill112x
        • Jan 2009
        • 4237
        Would it be to much to ask for pics of one of you guys setups?
        • xwill112x
          • Jan 2009
          • 4237
          there are 3 bolt holes? what is the extra for?
          • TimKninja
            • 2131
            I only had two....
            I sold my Car...you could PM turbo5ohh on here and maybe hell snap a pic?
            • fronton
              • Oct 2009
              • 1262
              A third hole means SLS leveling. You need a different pump. You can plug that hole and you'll get pressure problems, or loop that hole into one of the other lines. Or get a two hole pump.
