VIDEO DIY: How to wire your 24V motor ultimate noob guide
  • Styleprojekt
    • 287
    Right, Im sure a lot of charts actually in fact wrong/misleading/incorrectly documented I was not disagreeing with that, I just figured it would be safer to assume that the variables of each swap make it almost impossible to find a matching and accurate chart unless you can find your exact swap which matches all the way to each wire color.
    You're better off researching/compiling your own chart and learning something in the process...especially for those who are doing it for the first time
    • singh336
      • Dec 2010
      • 211
      so if there are so many changes with the wires between model and year how do those ultra expensive premade adapters work ? the plug and play ones for 200-250 bucks ?
      • bernzpeed
        • 3917
        you pay for the "minus the guesswork and headache" which inevitably might not be the right wiring for the specific car.
        i've heard of market motorworks takes your M5X/ S5X wiring harness and they retrofit it with the plug for the c101 with the right wiring but u will have to submit your vin to match up the exact wiring harness.
        89 E30 S52
        Transaction Feedback.
        • 328ijunkie
          • May 2007
          • 3961
          Most of the off the shelf adapters dont work 100%. When i rewire customers harnesses i require their BODY side C101 color/pin out before i make their harness to ensure everything works perfect.
          Check Us out on Facebook
          Full Product Line Tuning
          • vandy
            • Nov 2011
            • 130
            Originally posted by 328ijunkie
            Yeah i sold him an 'unmodified' harness and a C101 pigtail on the cheapz cause he wanted to tackle it himself. Looks like he did a good job!
            What year is your car btw? Whatd you do with pin 20?
            And i hate to bump this thread as it may hurt my business ;) lol
            I think the broken link in your sig may do more damage to business than this one post. :p
            • 328ijunkie
              • May 2007
              • 3961
              Epic fail. :(
              Fixed. Thanks for the heads up!
              • NbAmTwE
                • Jul 2010
                • 148
                This is very good info, thanks!
                UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
                stripped out e30 rally project - in progress
                M50NV -> M50TU E34 swap underway
                • bimmerteck
                  • 762
                  Not too bad for a first DIY video, I'd recommend either using factory butt crimps and heat shrink or soldering the wires and then heat shrinking rather than just the twisting and heat shrinking. You'll usually get better results from the factory wiring diagrams, but the online pinout charts are a good starting point and usually have the main required pins correct.
                  Adaptors are great if you aren't very confident in your skills, but I prefer to transplant the body side of the e36's x20 into the e30. It looks stock while allowing for every circuit of the e30 to function and leaves room to add extra pins to the motor harness for aftermarket gauges such as oil temp, oil pressure, ect. if you so desire. Another benefit to wiring the x20 to the e30 is that it reduces the potential failure points.
                  1. Cut off the c101.
                  2. Prep the wires.
                  3.Map the pins.
                  4. Insert the e30's harness into the x20.
                  • Rsully70sev
                    • 2391
                    Originally posted by Mr.SWISS
                    Holy hell you sound like a condescending douche! no offense!
                    lucky I wasn't there with Chuck on my shoulder telling me to shove my fist down your throat and rip out your larynx.
                    So what's wrong with Daves harness? my car runs fine.
                    And you sound like a whiney waffleswaffleswaffleswaffles. Chill the fuck out tough guy
                    Well done man, I'm sure this would be of great use to someone working on a swap.
                    • Blaine0002
                      • 382
                      2. Prep the wires.
                      3.Map the pins.
                      Awesome.
                      Where do you get the plugs and ends for these?
                      • bimmerteck
                        • 762
                        Originally posted by Blaine0002
                        Awesome.
                        I order the pins through my local parts dept. but most places that stock factory parts should be able to order them. The part # for the pins are in the full wiring 101 post taken from my build thread. ;-) I keep the seals to make the x20 weathertight from harness and circuits I remove from donor harnesses/connectors. Wiring 201 will be posted soon I just have to get my real camera back out into the garage to document what I did.
                        • Blaine0002
                          • 382
                          Thank you :O
                          Edit: do you know of anywhere you can order new seals?
                          • VinniE30
                            • 2113
                            Nice video. I watched the whole thing even though i'm not doing a 24v swap lol.
                            You should make more DIY videos. Maybe something like a complete 24v swap from start to finish - that would be epic.
                            Zinno '89 <24v swap in progress>
                            • lolcantturn
                              • 4588
                              I could do that, I wouldn't mind, gotta find me a car.
                              Originally posted by TSI
                              OEM+
                              • bimmerteck
                                • 762
                                Thank you :O
                                New Seals
                                This should be New plugs for unused pin locations.
