Bad MPGs?
  • Danny
    • 14216
    Bad MPGs?
    So I have a 95 S50B30US in my car. It has 21.5lb/hr injectors, 3.5" MAF, 16lb flywheel, a Bimmerworld boot and a TRM tune for them all. Currently I'm getting around 17 MPGs MAX. That's mixed driving. I get around 15 if I'm all city and around 18 if I'm all freeway.
    My question, are these low numbers for the mods listed, or are they correct and I just have to suck it up?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    I say suck it up.
    • Danny
      • 14216
      Issue is that I was getting a solid 19-20 in town and around 24-25 on the freeway before said mods were installed.
      • ethrtyiS
        • 8147
        yeah i have same mods on my s50, and i can honestly say, i may be taking them out and installing them only for track days. but currently i estimate 320-340 to the tank mixed driving.
        「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
        「my feedback thread」
        • Danny
          • 14216
          Okay yeah, I'm getting like 180 miles to 3/4s of a tank (when I usually refill.) That's 240 or so per tank. Almost a full 100 miles less than you.
          • ethrtyiS
            • 8147
            well i had to change how i drive. my foot feels like a feather.
            • Danny
              • 14216
              Driving habit may have something to do with it, but even so it seems low.
              • ethrtyiS
                • 8147
                also, my car weighs much more than yours.
                • Danny
                  • 14216
                  You have an E36 or something?
                  • ethrtyiS
                    • 8147
                    yes. i have e36 m3.
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      In the same boat, but I seem to have a much greater issue on my hands.
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                      • VinniE30
                        • 2113
                        The mods are surely contributing to it a little, but there's probably something else at play here.
                        Could be any number of things.
                        clogged cat
                        bad spark plug
                        fuel filter
                        low fuel pressure
                        intake filter
                        How many miles are on the s50? You should do a compression test.
                        Zinno '89 <24v swap in progress>
                        • FredK
                          • 14763
                          Yeah, I'd say that's a tad on the low side. I get around 18-19 in town, and 23-24 highway, with the same engine, and same mods--21.5lb/hr injectors, 3.5" MAF, BW air boot, TRM tune. I don't have a lightweight flywheel, but I do have fairly high gearing--1:1 5th gear with an S3.46.
                          • giantkeeper
                            • Aug 2009
                            • 1416
                            For me
                            95 S50B30US stock injectors, 3.5" MAF, stock flywheel, zf/3.15 lsd, BW boot and a TRM tune 21 mpg mixed driving
                            I'm convinced it's the box like design of the E30
                            Always Always go for the reach around if there is an option
                            • 325Projectz
                              • Jan 2005
                              • 1956
                              i'd say thats low... in my e30 m3 w/ 99 s52 obd1, 24lbs, 3.5 maf, uuc flywheel, zf/2.93, tuner tune, 26.5 mpg.
                              91 m3
