Bad MPGs?
  • Danny
    • 14216
    #31
    I forget what he said, but it made sense when he explained it. I'll call TRM Monday and ask.
    • CHITTY
      • 79
      #32
      Originally posted by Danny
      I just dropped off my car to have the A/C put in and my friend said he thinks its the tune, he thinks TRM sent me the tune for 24lb/hr injectors instead of 21.5lb/hr injectors and that's why there is a check engine light at high rpms.
      Hey Danny, who in the bay area is making your A/C lines for you. I need to get lines made up for my car.
      I also have a very similar set up as your motor but I am running a zf trans, gas mileage doesnt seem to bad (about the same fill ups as my m20 for my commute), but my odometer stoped working so I have no real MPG as of yet.
      http://importmotorsparts.com/
      • Danny
        • 14216
        #33
        Hey Greg, Milt's Service Garage in Vallejo is doing them for me.
        • CHITTY
          • 79
          #34
          Cool, I use to work with Adrian, I'll have to give him a call. I was thinking of ordering a set from Zionsville, but the out of stock and price turned me off from them.
          • LJ851
            • 7919
            #35
            Did you find your missing mpg, Danny?
            Lorin
            The M30 is God's engine.
            • Danny
              • 14216
              #36
              Not quite yet. I think a new tune from TRM using the stock MAF may have helped a bit however.
                • 34839
                #37
                there's no point to the bigger MAF, anyway.
                • 328ijunkie
                  • May 2007
                  • 3961
                  #38
                  ^That.
                  Check Us out on Facebook
                  Full Product Line Tuning
                  • MMontero
                    • Jun 2012
                    • 6
                    #39
                    E36 M50B25tu , 3.15 , stock 18mpg
                    is that bad mpg ?
                      • 34839
                      #40
                      yes, realistically a stock OBDII 325/328 should get high 20's low 30's.
                      • Danny
                        • 14216
                        #41
                        Okay so I need to get to the bottom of this ASAP. Anyone have the specs for ohms for the Cam, O2, Coolant temp, and any of sensors that could affect fuel trim?
                        • LowR3V'in
                          • 4209
                          #42
                          Offtopic but just thought is would be interesting to some.
                          I used to get 300miles to the tank on my eta.
                          I now get 160miles per tank on my turbo m30.
                          If you're getting 300mpt on a bolt on s50 I think it's pretty damn GOOD!
                          • Danny
                            • 14216
                            #43
                            I'm not though. I get around 180 to 3/4 of a tank. So figure 240 MPT.
                              • 34839
                              #44
                              I'm pretty sure even a modded S50 should get more than ~18mpg.
                              • Danny
                                • 14216
                                #45
                                That's why I need to start trouble shooting sensors.
