These are the things I plan to replace before I drop my obd1 m52 into the e30. Let me know if I missed anything I should change, and also if I am changing something that doesn't need to be. My hope is that I will address any potentially difficult parts to change while the motor is on the stand, to save headaches later.
Motor:
-oil pan gasket
-valve cover gasket
-water pump w/ metal impeller and new o-ring
-new rear main seal and housing
-new front crankshaft seal
-80 degree thermostat and new o-ring
Trans (G260):
-new front and rear seal
-new selector rod seal
-new clutch, pp and throw out bearing
-new pilot bearing
Thanks for the help!
Motor:
-oil pan gasket
-valve cover gasket
Trans (G260):
-new pilot bearing
