Engine stand recommendations?
  • PannikAttk
    • 120
    Just picked up an M52. I'm going to take my time with it and plan to go over it and replace as much as possible over the coming weeks. Will the Harbor Freight stand pictured be adequate?
    1990 BMW 325is 5spd - Brilliantrot
    M52 - Scorpion exhaust - GAZ Coilovers
  • Mr.SWISS
    • Nov 2005
    • 1251
    just barely, it sags a bit more than I like but I have seen others put a block of wood under the front and the block to aid support.
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
    • Slovik
      • Jan 2010
      • 198
      I had mine on that same one and it worked fine, lubricate the nose first so the engine can rotate more smoothly. You will have to adjust the arms because of the engines center of gravity but once you do that it works very well.
      • PannikAttk
        • 120
        Thanks fellas - just seems like it needs some adjusting to work well. I might jump on it.
        • wildstoats
          • Sep 2007
          • 896
          I had my m30 on one of those for a while. Held fine but it definitely made me nervous. I opted for the 2x4 support in the front for piece of mind.
          • hoveringuy
            • Dec 2005
            • 2715
            It will work, the important thing is that you try to align the center of mass with the yoke. Otherwise, you'll rotate the engine and it will want to topple.
            • ACHTUNG
              • May 2005
              • 2397
              Mine worked fine.
              1989 US E30 Cammed S52
              Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
              • !kid
                • 1362
                We have a VK56 long block siting on a harbor freight engine stand at my work. Your m52 wil be just fine.
                :borg:
                • Thrizzle
                  • Aug 2011
                  • 194
                  s52 sat on my harbor freight stand for a couple months, no problem.
                  • cmybimmer
                    • 894
                    Used the same one for the m50, sat there for about 5 month's without a problem. I believe you're only able to line up the engine to three of the mounting arms.. From what i've read up on, and thats what I had to do too.
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      I got an AC Delco one from Autozone a few years back for $129 Held my S52 for about 6 months on the stand.
                      :nice:
                      • eurosport22
                        • 210
                        mine has been on the stand for about a month. everything is still on the engine and it doesnt sag at all
                        • ACHTUNG
                          • May 2005
                          • 2397
                          This is how mine sat for about 2 months. No sagging and no problems at all.
                          • Pudmunkie
                            • 210
                            My s50 has been sitting on the harbor freight stand for at least 9 months centered with all 4 arms.. no issues
                            Sent from {smartphone;}
                            • SpeedRacer85
                              • Jul 2011
                              • 424
                              Same here Harbor Freight stand is strudy enough.
