M42-S50 swap... I have many questions
  • B2ThaZiZza
    • Aug 2004
    • 614
    Is this list correct?
    3.91 LSD
    535i brake booster
    740i master cylinder
    Tree house racing harness adapter
    ABS pigtail adapter
    M5 motor mounts
    e30 M3 driveshaft
    e34 oilpan?
    What else do I need before i start ripping out the motor?
  • permit
    • Mar 2005
    • 3363
    e36 motor mount arms
    e34 oil pump pickup arm
    535 boosters work? I thought it was just ix or 320i, cool.
    • King Luis
      • Sep 2004
      • 737
      just a quick question: the THR harness listed as an M50 will work for the S50 also?
      • Jarvis
        • 2132
        Originally posted by B2ThaZiZza
        e30 M3 driveshaft
        So you're using an E36 transmission? In that case...
        3.91 LSD
        ... your gearing is going to be ridiculously short.
        • DEV0 E30
          • Oct 2004
          • 8892
          If you rarely go onto the freeway is the only real reason to have that Diff. I have a 3.73 LSD and I think it's perfect, however many use the 3.25 LSD.
          May want to have a mod throw this in the M50/S50 swap sub forum.
          • permit
            • Mar 2005
            • 3363
            Boo on the e36 tranny, boo on the choice of diff.
            You'd be much happier with a 3.73LSD.
            • B2ThaZiZza
              • Aug 2004
              • 614
              i havent bought the driveshaft or a tranny yet so im trying to get an idea on what i need. I do drive on the freeway but its not an issue ill be worried about if run with a 3.91 but a 3.73 is what many people have been telling me to use. Im looking for a tranny that has pretty close gears but has a higher 5th gear for cruising on the freeway, what about a getrag 260?
              • Skafrog
                • 1732
                yes.
                NASA MidSouth TT Director / GTS2 #018
                Mods: Coastal PS Fluid, 10w40 Oil
                Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                • 02stu
                  • Jan 2005
                  • 872
                  So if you use the stock e30 trany what driveshaft do you use?
                  • erik325i
                    • Jan 2005
                    • 3567
                    stock driveshaft
                    • windnsea00
                      • 158
                      If using a Getrag 260 tranny go somewhere between 3.25-3.73...I had a 4.10 for awhile which was rediculously short then went 2.93 which took to long to get into "Vanos" period.
                      Past: 1991 330is; 1995 318ti; 1993 325is; 1997 318ti; 1989 332is; 1999 Z3 M Coupe
