Ecu reseting
  • Tomas
    • Mar 2012
    • 11
    Ecu reseting
    Hello, how can i reset m52b28tu DME without laptop?
    (The engine is not in stock car)
  • ForcedFirebird
    • Feb 2007
    • 8300
    OBD2 scanner usually has a reset function.
    john@m20guru.com
    Links:
    • Tomas
      • Mar 2012
      • 11
      maybe i dont need to resset ECu after changing lambda sensor?
      • ForcedFirebird
        • Feb 2007
        • 8300
        If the check engine light is on, it's faster to reset, but will go out if the issue was fixed and you pass through 3 full driving cycles (usually a few days of daily driving).
        john@m20guru.com
        Links:
        • Tomas
          • Mar 2012
          • 11
          Thx man!
