944 ATE booster / master cylinder question
  • 36brua
    • 689
    I've read a couple of places the booster/master cylinder should be from same mfg'r. Car is 89 I and has Girling MC. I'm leaning towards using the ATE 944 booster for my swap. Will the Girling MC work or do I need an ATE MC? Different mounting,seals,stroke or? Any comments about this combo ? Thanks
    My CA legal M60 swap
    The happening in our garage
  • FredK
    • 14763
    You can use the stock Girling MC with the ATE 944 booster. The master cylinder mounting is identical.
    In my opinion, it is the best feeling single booster setup and the stock stepped 22/17mm MC is also a logical master cylinder choice. People often "upgrade" to a 25mm MC, but honestly, I don't like the shorter stroke, as it complicates heel-toe shifting because the larger difference in pedal height between the accelerator and brake pedals.
    • 36brua
      • 689
      Thanks for the info^
      • gkurey
        • 882
        I also use it, although brake performance is there, you have to hit the pedal harder than you are used to to achieve the same effect...which should be expected due to it's smaller diameter. Switching to this MC allowed the intake mani to *just* fit; and I sanded/ground off the last 2-3 fins on the intake to maximize clearance.
        • charlie2309
          • May 2011
          • 103
          just installed my ate 944 booster with oe e30 mc, it is a tight fit, also had to shave down those last few fins on the intake. But it does fit, and has a nice pedal, sligtly more effort, but I like. Modifying the rod is super simple too, ten minutes with a cut off wheel and a 5. dollar harbor freight cutting die, and you're good to go.
          • 36brua
            • 689
            thanks for all the input :D
            • JRKOUPE
              • Dec 2004
              • 3159
              I run it as well.......I like it....on the track I like the feel for aggressive pedal action....fine on street as well....
              ......really feels very close to stock .
              • e30rapidic
                • 2167
                I run a 944 turbo booster and 7 series master cylinder. I did not have to shave any fins off my intake manifold.
                '87 325ic, powered by S50.
                • M///BMW
                  • 216
                  I am in the process of modifying my 944 booster. Does anyone have a DIY on it?
                  • Jand3rson
                    • 37587
                    This thread was literally 8 threads below the one you just posted in.
