s52 e30 m3 - Continuous Battery Drain - fuse 23 + 24 when car is off
  • r4esh
    • Jan 2010
    • 439
    Hey all, just sorting out stuff on my s52 swapped e30 m3. I have an annoying battery drain when the car is off on fuse 23 & 24. Its not a lot, but it will drain dead after 24 hours. I'm not sure how to hunt this down. Any ideas?
    There is no radio hooked up. And I checked the infamous "trunk" cables to see if maybe they were crimped / split. Which there was a broken wire. I soldered it back but I still have my drain and I don't think that wire was related.
    (oo=[][]=oo)
    Web Design PNW
  • e30rapidic
    • 2167
    my glove box light was staying on and causing my battery to drain. It had come loose in the housing! Took me a while to track that one down!
    '87 325ic, powered by S50.
    • 328ijunkie
      • May 2007
      • 3961
      Fuse 21 is:
      Chime modlule, Cluster, Radio, Trunk Light, Check control Unit and interior lights. Get a multimeter and unplug 1 by 1 and see if the drain disappears
      Check Us out on Facebook
      Full Product Line Tuning
      • r4esh
        • Jan 2010
        • 439
        EDIT: So I went back and checked right now and I'm getting power on fuses 23 and 24 when the car is off and NOT fuse 21 like I thought.
        (oo=[][]=oo)
        Web Design PNW
        • 328ijunkie
          • May 2007
          • 3961
          just cause youre getting power to fuses doesnt mean their draining anything. you need to do a amp drain test. You know how?
          • drez14
            • Jun 2011
            • 211
            try this:
            • r4esh
              • Jan 2010
              • 439
              Originally posted by drez14
              Great video! I was in the dark until I watched this. I will report back. I know that there are some fuses that ARE supposed to be "Always on", but I've tested 2 working batteries now and they both died within 24 hours so I'll follow that process and narrow it down.
              (oo=[][]=oo)
              Web Design PNW
              • matthugie
                • Mar 2004
                • 1810
                This is a glorious thread for me right now. I've had a draw for so long, but didn't really know how to find it. I've just been unhooking my battery if I park the car for more than a few days.
                88 325is - S52 powered
                Originally posted by King Arthur
                We'll not risk another frontal assault, that rabbit's dynamite!
                • reelizmpro
                  • 9553
                  Is your trunk light turning off? meaning...is your trunk misadjusted? Make sure the latch is tight so that when you close the trunk it's not so loose that the switch isn't making full contact and leaving the light on in the trunk. This one is often looked over so I thought I'd mention it right off the bat.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • r4esh
                    • Jan 2010
                    • 439
                    So "drez14"s video link was great. I haven't gotten that far... but I have noticed something... Non of my interior lights NOR my trunk light will turn on.... what gives?! No blown fuses! Everything worked before the swap and I can't imagine my swap wiring had anything to do with it...
                    (oo=[][]=oo)
                    Web Design PNW
                    • drez14
                      • Jun 2011
                      • 211
                      Yah. I thought that video was a gem that I had to share. I thought my trunk or glovebox light was staying on. Simple test. Put my iPhone on record, threw it in the box, recorded the light turn off.
                      Are all your connections at the distribution box correct?
                      • 328ijunkie
                        • May 2007
                        • 3961
                        Do you have power for the lights anywhere
                        • Lof8
                          • Oct 2006
                          • 2827
                          subscribed to watch the video later.
                          S50'd
                          Originally posted by TDE30
                          What is this faggy shit I have happened upon?
                          I can always live in a M3. Can't M3 a house.
                          • r4esh
                            • Jan 2010
                            • 439
                            So my battery drain is gone. Interior lights are working. I found a broken wire that runs up the trunk hinge and i believe runs to the sensor to signal the trunk light on / off. Repaired the wire and my drain is gone for anyone who reads this / is tracing down their own battery drain.
                            (oo=[][]=oo)
                            Web Design PNW
