What type of oil do you use?
  • Robert
    • Dec 2010
    • 3770
    I wanna see the types of oils people use in the DOHC
    Synthetic or Conventional?
    What weight?
  • driftingminor913
    • Sep 2011
    • 358
    10w-40 mobil1 high mileage
    Because V8
    http://www.r3vlimited.com/board/showthread.php?t=282219
    Doing it wrong since 91:wgaf:
    • Thrizzle
      • Aug 2011
      • 194
      mobil1 0w-40 in my 116k s52.
      Have ran 0w-40 in my other s52 from 120k to 150k with no problems.
      • !kid
        • 1362
        It also depends on the climate you live in too. Someone that lives Alaska should not be using the same viscosity oil that someone in Arizona is using.
        FYI
        (10w30)
        10w= the viscosity of the oil measured at 0 deg
        "w" meaning winter grade
        30= the viscosity of an oil when measured at 212 deg
        Viscosity is resistance to flow.
        An oil with high viscosity will be thicker than an oil with low viscosity.
        :borg:
        • justin_l_
          • Jun 2007
          • 1079
          I run Valvoline VR1 20w50 High zinc/phosperous ftw
          • ThisGuy310
            • Jun 2010
            • 433
            oil.
            • JA1991
              • 452
              15w50 full syn mobil1
              • JA1991
                • 452
                car has 200k miles and runs strong.
                • Tico Frank
                  • Feb 2011
                  • 351
                  You should all use Castrol since thats what BMW uses.
                  • Kumi
                    • 31
                    Castrol GTX 20w50 past 2 E30s have ran great, and reliable for about 150k miles on the first one, and about 90k miles on the current one.
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      15w-50 fully synthetic in the summer and 5w-30 in the winter, also fully synthetic.
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        You should be running full synthetic in your 24v VANOS motors.
                        Period.
                        john@m20guru.com
                        Links:
                        • lolcantturn
                          • 4588
                          Shell Rotella
                          Since we're on the topic, how often should one change the oil on these motors? I feel like I've been changing mine every 3000 miles lol.
                          Originally posted by TSI
                          OEM+
                          • drumad
                            • Aug 2009
                            • 1700
                            German Castrol. 0W30.
                            Mmm green oil.
                            2008 335i - n54b30
                            1991 318i - m52b28
                            1994 fzj80 - LAND CRUSHER
                            • 89 e30
                              • 249
                              rotella 20w50 in summer and 0w0 water in winter
                              BIMMER für IMMER
