Ok, flame me if you must. I have been searching for the past couple of hours about this and i still dont know the definitive correct answer. (too many posts with incomplete information about their chassis/motor etc.)
Anyways. I have a 89 325i (build date 9/88.) with a 99 s52 converted to obd1. Running a 502 DME with Conforti tune (Euro HFM, Stock inj.)
I have connected my pin 14 from my engine side to pin 14 body side.
Do i still need to connect a wire from the green clip on the back of my cluster to pin 42 on the dme to feed it the vss signal? I can definatly rev past 6k, so does that mean the dme is getting the correct signal?
I cant tell from all the searched threads if this manually wired fix from cluster to dme is for early cars, or e cars only, or for all.....
Thanks
Thanks
