m52 cfont crank seal good idea?
  • frankie591
    • Feb 2012
    • 545
    Should I replace the front crankshaft seal on my m52 while its on the stand, or am I opening a can of worms? I don't know the history of the motor, the timing cover looks fairly clean so I assume the seal isn't leaking much if at all. I bought the seal along with a bunch of other stuff, but after reading what is required to change it, I'm having second thoughts and think I might just skip installing it unless I have a problem.
    Thoughts?
  • reelizmpro
    • 9553
    Hmmm probably not unless you are doing other things to the engine. Do you know the mileage? It's a peace of mind kind of thing.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • frankie591
      • Feb 2012
      • 545
      I'm doing most seals on the motor, water pump, tstat, vc and oil pan gasket. I was told the motor has 100k, with a rebuild at 50k, and judging by the shape of the head and bottom end I believe that mileage is fairly accurate.
      • reelizmpro
        • 9553
        If it was rebuilt, chances are they changed the front seal as the cover has to be removed and you said that the area is clean and doesn't seem to be leaking. I wouldn't worry about it in that case.
        88 M3 - LACHSSILBER
        • Adrian_Visser
          • Jun 2006
          • 2823
          Murphy's law says it will start leaking one month after you get the car on the road. Remember the crank nut is torqued to 300ft lbs, you need to hold the crank from spinning somehow. Either by using the holding tool attached to the stock flywheel or if you are using an aftermarket flywheel by putting a 2x4 between the block and a crank throw with the oil pan off or making a tool to connect to the harmonic balancer bolts.
          '89 Alpine S52 with goodies
          • jrdeamicis
            • Nov 2008
            • 956
            The front main seal. HELL YES you should replace it. Its not hard, just crack the crank bolt, 3 jaw puller the flange off.
            MANDATORY
            Front main seal
            Rear main seal
            Oil Pan
            Head Gasket
            Intake
            Exhaust
            Oil Filter housing
            Wait... I am just listing the gasket set. Replace everything because i promise you, nothing is worse than having a brand new engine leak.
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
            • bimmerteck
              • 762
              QFT
              It will never be easier to replace ALL the gaskets on that motor than when it's on the stand, don't forget the gasket for the heater hose flange on the back of the head, the rear main seal housing gasket, and the timing cover gaskets.
              • 7pilot
                • 475
                If you are going to use a synthetic oil...Change it.
                m
                • frankie591
                  • Feb 2012
                  • 545
                  Would a 4x4 wood block wedged between the crank counterweights and the block cause any damage to the crank or the block?
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    Nope, I use a wedge all the time to stop the crank from rotation so I could crack the bolt.
                    BNB Designs
                    Richmond CA
                    Julian 848-248-8029
                    • 328ijunkie
                      • May 2007
                      • 3961
                      Big impact gun ;)
                      Check Us out on Facebook
                      Full Product Line Tuning
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        Originally posted by 328ijunkie
                        Big impact gun ;)
                        BIG. Most people don't have access to an impact that large.
                        BNB Designs
                        Richmond CA
                        Julian 848-248-8029
                        • howelll
                          • Sep 2009
                          • 198
                          I used my 5 ft jack handle over my 1/2 in drive rachet to pull it off, then unbolted the lower timing cover and pressed out the seal from the back side.
                          • Adrian_Visser
                            • Jun 2006
                            • 2823
                            3/4" dr breaker bar ftw
