I need to re-hone my block, and wanted to know what my bore should be(how far from stock it can be, e34 m50b25tu,) it Will have new rings of course.
M50 bore tolerances?
Tags: None
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard. -
You can go up .025, but you need to match the pistons to the bore size. You can easily order .025 pistons w/ rings.
S52 is 86.4 if I remember correctly.
You should just swap out to the M52 crank and do a 2.8 setup with .025 pistons. Best of both worlds.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
Stock pistons are 83.98" (b25) and the bore is 84mm. Just a hair tighter than 1.5 thou...
.02mm=.0008"Comment
You can do either with that setup. They're custom pistons he's referring to.
This is similar to the Frankenstein M50 setup just with overbore and custom pistons. So you can choose pistons that will raise/lower compression depending on na/FIUNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
stripped out e30 rally project - in progress
M50NV -> M50TU E34 swap underway
it would have compression like a M54b30 or s52b32; m54b30 is a small bore s52. Not very high compression, a S52b32 usa is a low performance engine with relatively low compression.
The 3.0 L crank has a longer stroke, that is why the same 84mm bore (or overbore) can equate a total of 3000cc instead of 2500cc.
If you desired 3200cc you could bore your m50 block to 86.4mm and use the s52 crank and rods in your block.OBD1 M54/M52TU swap as a M50b25
