latest issue after I started to dailying my car. brake light switch will not allow my brake pedal to release all the way causing my brakes to lock up unless I pull the switch. any ideas?
					brake light switch and brakes locking up
 booster setup?
 Check Us out on Facebook
 Full Product Line Tuning
 Sounds like you need to screw down the clevis on the end of your booster a bit to shorten the rod. You don't need to disconnect the booster from your pedal. Just break the 17mm nut loose and twist the rod with a pair of pliers until the pedal starts to back off of the switch. Once the brake lights stay on all the time you've gone too far.
 -StevenComment
