Not Cranking
  • Slovik
    • Jan 2010
    • 198
    Not Cranking
    Just finishing up my s52 OBD2 swap and I went to start it for the first time. I get a click but no crank from the starter. I had the starter checked at the auto parts store before installing. The flywheel is a shaved m20 and the starter is an m20. Do all m20 starters work with all M20 flywheels? Battery is strong, power to DME. Could the starter jamb, hate to take it back apart again. Any and all ideas welcome.
    Thanks,
    Seth
  • Thrizzle
    • Aug 2011
    • 194
    I had a click and no start at first as well. I had a poor engine ground. Mounted the engine ground up to a better spot and it started.
    • Slovik
      • Jan 2010
      • 198
      I have mine from the standard spot on the inside of the frame rail to the engine arm, where did you use your ground
      Thanks,
      Seth
      • Thrizzle
        • Aug 2011
        • 194
        I had mine to a janky clip on the strut tower, relocated it to a solid spot on the strut tower.
        How are your other grounds? You should have 4 in total I think?
        • Slovik
          • Jan 2010
          • 198
          I have 3 I think, the 2 coil grounds and the main ground. I will reground the main one, I think I may even just run out and get a new grounding strap as mine is 21 years old.
          • SwiftE30
            • Jun 2010
            • 998
            I had the same problem. i had my starter jam even after i checked it out. They can get stuck sometimes. All i did was take a long piece of 1x1 wood and set it up against the starter and tapped the end of it a few times with a hammer. Started right up after that.
            1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
            • Slovik
              • Jan 2010
              • 198
              You know I was thinking that, back in the day (I'm old) my Father's Fiat 128SL responded to that and I've never forgotten, It's worth a try.
              Thanks,
              Seth
              • Slovik
                • Jan 2010
                • 198
                No Go on Tapping the starter and I replaced the main ground with a new one. Any other ideas?
                • Thrizzle
                  • Aug 2011
                  • 194
                  Should be 4 grounds-2 at the front battery tray, 1 on the right side of the engine, and one is at the front most part of the top of the engine, right by the ccv
                  • SwiftE30
                    • Jun 2010
                    • 998
                    i know the ECU is supposed to be grounded through the harness, but some people have had this problem and simply added an extra ground wire from the ECU case to the strut tower, or wherever you want... according to them, this fixed their problem
                    • drez14
                      • Jun 2011
                      • 211
                      +1 on the grounding. I bought a new ground strap and sanded down the ground spot on the pass side frame rail.
                      • Slovik
                        • Jan 2010
                        • 198
                        Thanks Everyone, I will be trying all the grounding tomorrow.
                        • 328ijunkie
                          • May 2007
                          • 3961
                          just short the starter. Big terminal on the bottom to the positive in the middle. See if it works. Use a ~16 gauge or bigger wire. If it doesnt you have other issues.
                          Check Us out on Facebook
                          Full Product Line Tuning
                          • e30rapidic
                            • 2167
                            put a charger on the battery. Went over a swap 50 times and everything checked out but it still wouldn't crank.
                            All the lights and gauges were coming on but the battery didn't have enough juice to turn the engine. Hooked a charger up and voila...
                            '87 325ic, powered by S50.
                            • drez14
                              • Jun 2011
                              • 211
                              Also,
                              Early on in my swap i was able to crank, then all of a sudden i was not. the started would click but not turn. After further inspection, i realized that one of my injectors was stuck open and filled one of the cylinders with gas causing it to lock.
