Coolant hose
  • CHITTY
    • 79
    Coolant hose
    Anybody have a s52/m52 swap that is running a m20 rad and late model resivoir tank? I am trying to figure out what hose to use from the tank to the metal coolant pipe under the intake. I'm thinking that I could use #8 (11531740649) http://www.realoem.com/bmw/showparts...89&hg=11&fg=35. Any help is appreciated.
    And yes I have searched but came up with nothing solid. Thanks again.
    http://importmotorsparts.com/
  • MaxBell
    • 1391
    I'm using the E34 rad hoses.
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
    • 328ijunkie
      • May 2007
      • 3961
      I always swipe a section of the m20 hose.
      Check Us out on Facebook
      Full Product Line Tuning
      • m_dudey
        • 267
        i used a portion of the m20 hose as well
        • CHITTY
          • 79
          Thanks, I cut mine to short when I did, and it seems to be a tad bit small to fit over the metal pipe. Was just wondering if anybody did it different.
          • bzboardz
            • 1096
            mine was to small in diameter, finally got it on there though
            • mtlbloodshot
              • Jul 2011
              • 761
              What hose must be used when using a M42 RAD on a M52?
              MY BUILD THREAD
              http://www.r3vlimited.com/board/showthread.php?t=235231
              INSTAGRAM : @luchcolaneri
              • tonytony
                Knee deep in poopie
                • Jan 2004
                • 3498
                IIRC I used e36 hose and trimmed a bit, I'm using a m42 radiator
                • blackhawkimpact
                  • 2415
                  ^Yes
