Sunbelt or schrick cams
  • 510e36
    • 112
    I've always thought sunbelt cams were a hot cam? And always sounded loopy I wanted a street cam that I could dd. and what's a MM cam?
    • valleymotorwerks
      • Jul 2005
      • 174
      Just a different brand of regrind...
      Valley Motorwerks
      1988 E30M3
      • Bimmerman325i
        • 6854
        Yes....but depends which cam you're talking about. There are three sunbelts, you're likely thinking of the Race cam.
        Sunbelt Sports are hotter than Schrick or MM, and might need VANOS to be shimmed.
        Sunbelt OBDII cams are similar to MMs, no Vanos shimming needed afaik (these are used in Bimmerworld's kit)
        Sunbelt Race are a true race cam. Vanos needs to be shimmed almost to the point of uselessness, and as a result, you won't make power until 5000rpm.
        MM = Metric Mechanic.
        2017 Chevrolet SS, 6MT
        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
        98 M3/4/5 (stock)
        • surebimmer
          • Jan 2004
          • 978
          Originally posted by valleymotorwerks
          Sunbelt / Bimmerworld is the setup I ran on my BMWCCA IP car... it uses the 540 maf too, you need to be careful since the cams require that the VANOS be limited in movement. DRVANOS sells a limited vanos that works well. Bimmerworld has the software for it. My current S52 is running Dynospot cams and software. I like the Dynospot setup more AND it's much less expensive.
          EDIT: I passed smog with flying colors BTW
          Dynospot from san jose? How much did cams cost? I have a set of sunbelts in my m3 and love them.
          • Rsully70sev
            • 2391
            It seems like Sunbelt's are perfered, but what about the Schrick Cam Kit it seems like a lot of "bang for your buck" IMO.
            • Bimmerman325i
              • 6854
              What are you trying to do with the car?
              Sunbelts are for maximum power, but they trade low end torque for top end power.
              Schricks are a no-compromise cam, but because they're more of an OEM+ cam, they have less top end than Sunbelts. Typical gains are in the 10whp avg range.
              There are many many many dynos on bf.c of schrick vs sunbelt vs * cams.
              98 M3/4/5 (stock)
              • dougsic
                • Jun 2006
                • 284
                I have this exact kit plus headers but there is no way it produces 57hp as claimed.
                You cannot tell cams are installed while idling and there is a decent rush at 4k as the motor comes up on the cams but 57 hp?
                I have no experience with other brands but wouldn't be surprised if they offer more power.
                • Rsully70sev
                  • 2391
                  I was skeptical on the "57hp" but they have dyno charts posted lol. I guess there are variables to be taken into consideration.
                  • Rsully70sev
                    • 2391
                    So for $2,500 it's underrated? [Schrick cam kit]
                    • Bimmerman325i
                      • 6854
                      Well, it depends. What is your power goal? With FULL bolt ons (headers, exhaust, intake) on an S52, I've seen a few dynos between 260-270whp. I've seen many more dynos in the 250whp range, either from poor tune or not having the needed bolt ons for max power (aka emissions compliance took its toll).
                      98 M3/4/5 (stock)
                      • Rsully70sev
                        • 2391
                        I haven't quite decided. I'd like to stay NA but if $3k isn't going to go that far, I might go with a low boost set up through blueapplesoda for $6kish. Looking for 300's. Atleast to the crank. The S50 is quick, but I'm ready to bring it to another level. Just not sure what level that is.
                        • Bimmerman325i
                          • 6854
                          Well, to get 300 crank out of an s50 you will need cams, header, exhaust, injectors, and 3.5" maf/intake, as well as a solid tune. That will definitely push you over $3k unless you buy everything used. If your car is a street car primarily, I would go turbo.
                          98 M3/4/5 (stock)
                          • 328ijunkie
                            • May 2007
                            • 3961
                            Technica also has great cam tunes
                            Check Us out on Facebook
                            Full Product Line Tuning
                            • surebimmer
                              • Jan 2004
                              • 978
                              Link? More info?
                              • Beej '86 325es
                                • 2639
                                ^this
                                One-stop automotive repair facility for maintenance, repair and performance upgrades. 4-wheel drive Dyno Available for rent. Smyrna, Georgia, Atlanta.
                                -Brandon
                                '86 325es S50
                                '12 VW GTI Autobahn DSG
                                '03 540i M-Sport (sold)
                                '08 Jeep SRT-8 (sold)
                                For sale:
                                S50 TMS chip for Schricks
