Sunbelt or schrick cams
  • 510e36
    • 112
    I'm thinking about running a set of cams for my s50, but I need a custom tune. I'm running a 3.5 hfm, 24lb and headers and full track exhaust setup. Does anyone know of a company that affordable that makes a obd1 tune?
    • 37833
    The Racer's Market.
    Grover Beach, California
    BimmerHeads.com
    • frankie591
      • Feb 2012
      • 545
      ^them
      • Beej '86 325es
        • 2639
        If you go with the Schricks, I have a used Turner chip for this exact setup. I bought it just as a starter chip to get my custom motor running. I'll get it to you for a steal.
        -Brandon
        '86 325es S50
        '12 VW GTI Autobahn DSG
        '03 540i M-Sport (sold)
        '08 Jeep SRT-8 (sold)
        For sale:
        S50 TMS chip for Schricks
        • Adrian_Visser
          • Jun 2006
          • 2823
          Don't waste your money on Shricks, if you want NA power get the Sunbelts,. If you plan on going S/C though get the Shricks. That said I think you might need to limit the VANOS travel with the Sunbelts.
          '89 Alpine S52 with goodies
          • ACHTUNG
            • May 2005
            • 2397
            I have a set of Schricks, 24lb injectors, 3.5 HFM, headers, custom exhaust and a light weight flywheel. I have a TRM tune for my setup and am very happy with it.
            1989 US E30 Cammed S52
            Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
            • Wh33lhop
              • 11705
              Or you can get MM cams, add area under the curve and keep vanos.
              paint sucks
              • Adrian_Visser
                • Jun 2006
                • 2823
                MM does 24v cams now?
                • dougsic
                  • Jun 2006
                  • 284
                  I have a TMS setup with Shricks, 540 MAF, injectors, etc.
                  The car idles perfectly and runs very well BUT . . .
                  In Maryland, we have emissions testing every two years. Stock s50 passed with flying colors for many years. Installed Shricks and now it fails miserably. Replaced the cat a few times with various ones but the car still never passes.
                  May not apply to you but if you have emissions testing, be forewarned.
                  • justin_l_
                    • Jun 2007
                    • 1079
                    Failing emission testing is because of the tune, not the cams.
                    • dougsic
                      • Jun 2006
                      • 284
                      Good point. But with the duration (overlap) of the Shrick cams, can they be tuned to pass emissions?
                      I assumed (perhaps incorrectly) that since the cams were bought as a kit from TMS that included all of the components, the tune would have been spot on.
                      Does anyone have Shrick cams installed that pass emissions testing?
                      • valleymotorwerks
                        • Jul 2005
                        • 174
                        Sunbelt / Bimmerworld is the setup I ran on my BMWCCA IP car... it uses the 540 maf too, you need to be careful since the cams require that the VANOS be limited in movement. DRVANOS sells a limited vanos that works well. Bimmerworld has the software for it. My current S52 is running Dynospot cams and software. I like the Dynospot setup more AND it's much less expensive.
                        EDIT: I passed smog with flying colors BTW
                        Valley Motorwerks
                        1988 E30M3
                        • Bimmerman325i
                          • 6854
                          Yup. The MM "Rally" cams are more aggressive than the common Schrick setup but don't require a shimmed vanos or large relief pistons.
                          Active Autowerke also has good tunes.
                          2017 Chevrolet SS, 6MT
                          95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                          98 M3/4/5 (stock)
                          • 2quikmotorwerks
                            • Oct 2006
                            • 154
                            Mm?
                            • giantkeeper
                              • Aug 2009
                              • 1416
                              Metric mechanic
                              Always Always go for the reach around if there is an option
