m50 limp mode
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    m50 limp mode
    Car is an 86, motor from 93 325iS 413 dme, damn thing keeps going into limp mode after i hit about 65-70 mph. Wont rev past 3500rpm. I can drive it around town for days and it does just fine until i hit the highway and then kicks into limp mode. No cel, vss is hooked up. I am using the e36 harnes with what i think is the gregslow harness adapter. Engine harness is out of an auto e36, i didnt cut anything out of the engine harness cause im not sure what to do with the two wies connecting the trans and engine harness. Halp please
    -Andy
  • German Audio Specialties
    • Feb 2012
    • 374
    Dude, I totally forgot to call you back. I am sorry, my man, too much shit on my mind. Hope you get this figured out!
    Luke
    August R3VLimited Special: E3012 "V3" box: $225 shipped
    Tutorials: Killer $500 Stereo | E30 Vert Dual 8'' Box Installation | E3010 Amp Rack Installation | Radio Wiring and Amp Bypass
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      I think i have vss hooked up correctly. I have the wire plugged in to the green thing on the rear of the cluster behind the speedo. Plugged in to one of the terminals farthest to driver side. Is this right?
      -Andy
      • SkorcherX
        • Jun 2011
        • 267
        VSS Should be pinned here:
        Also I am in Eugene... not how much help I can be, but I am willing.
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          I hooked it up to one of those yesterday, had it in different ones before. We will see.
          -Andy
          • e30rapidic
            • 2167
            I ran into this. Turned out my VANOS was timed incorrectly. After I took it all apart and re-set it, problem was resolved. If I babied it, would rev ok but if I gave it anything more at all, it would just die at 3500.
            Also I hooked up my VSS signal using the C104, its kind of between the radio and glove box.
            '87 325ic, powered by S50.
            • dashboardmonkey
              FUCK YOUR WAFFLES
              • Jun 2008
              • 6158
              Im gonna check some shit out when i do the valve cover gasket. My vanos is a little noisy at startup so im sure something is going on in there
              -Andy
