Dead spot at 6500 rpm
  • Plynch2
    • Apr 2012
    • 56
    Hey guys I have an m52 out of a 96 328 it's obd1 converted s52 cams 24lb injectors eBay headers and TRM chip the engine runs fine untill 6500 rpm on a wide open pull then it hits a dead spot stops pulling hard. I was wondering if anybody els had this problem thanks. :down:
  • frankie591
    • Feb 2012
    • 545
    is it throwing any codes when you stomp test it?
    • Plynch2
      • Apr 2012
      • 56
      That's a problem whoever made my harness did not make the check engine light work.
      • drez14
        • Jun 2011
        • 211
        try changing your fuel filter?
        • AndrewBird
          The Mad Scientist
          • 11898
          Fuel pump might be going out as well.
          When does an M52 make peak torque? Could just be hitting the top of the power you have. I mean, why do you need to be accelerating hard at 6500 RPM anyway?
          • Beej '86 325es
            • 2639
            What year/model is your chassis?
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • 328ijunkie
              • May 2007
              • 3961
              If you dont have a cel you prob dont have a VSS signal either.
              Check Us out on Facebook
              Full Product Line Tuning
              • frankie591
                • Feb 2012
                • 545
                Pretty easy to peel back the c101 and x20 plugs and connect the necessary wires. May as well make it right
                • Plynch2
                  • Apr 2012
                  • 56
                  The car is a 89 I replaced the fuel filter and pump. When I unplug the ecu it runs like crap for like 20 miles within that time it will rev out great. I don't need to rev that far I'm jest worried I have power loss in other places.
                  • SkorcherX
                    • Jun 2011
                    • 267
                    Originally posted by Plynch2
                    When I unplug the ecu it runs like crap...
                    How does it even run? Did you mean to say you unplugged the MAF? Or maybe the O2?
                    • Beej '86 325es
                      • 2639
                      I would revisit your wire harness adapter first thing and verify you have these connections:
                      E30 C101 pin 12 to E36 X20 pin 8 (engine check light)
                      E30 C101 pin 14 to E36 X20 pin 14 (road speed signal)
                      -Brandon
                      '86 325es S50
                      For sale:
                      • Plynch2
                        • Apr 2012
                        • 56
                        Sorry when I unplug the ecu resets and it runs like crap. As for the wire there is a wight and black wire at pin 8 on e36 and on pin 12 e36 there is a brown wire that has been cut there is a big green and black wire going into pin 14 e36.
