Last month I had a problem with my electric fan in my car that caused my engine to overheat and crack the cylinder head while sitting at idle in the state inspection station.
In the wake of this failure, I'm considering putting the stock style coolant pump mounted mechanical fan and I'm wondering which parts are needed to make this work.
One site that I read said that you need to use an m20 clutch and 9 blade fan. It also said that you need to put metal cups over the trans mounts to keep the fan from contacting the radiator under hard braking. I am wondering if anybody has done this setup and also whether or not I need to use those cups over my poly trans mounts.
