Mechanical Fan
  • bimmer630
    • 1230
    Does anyone have a fan that will install WITHOUT removing the radiator? And how does that diesel fan look in there?
    • TimKninja
      • 2131
      +1 .
      And a BMW part number for the skinniest fan available ?
      1985 325e M50TU(Sold)
      1991 318is Slicktop (Sold)
      1990 325is Brilliantrot S50/5 Lug Swapped.
      1992 525i Manual shitbox Winter Beater
      • sharky
        • Jan 2005
        • 2672
        http://www.ecstuning.com/Search/11522243303/ES24501/
        • TimKninja
          • 2131
          BRILLIANT! Thanks Sharky !
          • sharky
            • Jan 2005
            • 2672
            Welcome
            • bimmer630
              • 1230
              Anybody have experience mounting this fan to a normal E30 clutch? http://www.realoem.com/bmw/showparts...=11&fg=35&hl=6
              Real oem says fan blades are only in conjunction with 11522245498 clutch
              • Mr.SWISS
                • Nov 2005
                • 1251
                Whoa....
                Why hasn't anyone mentioned these before?!?!?!?!?
                Originally posted by 325Projectz
                don't listen to the diagram... listen to mr. swiss.
                :nice:
                • Gooch
                  • Dec 2006
                  • 1674
                  Does anyone have an answer to this question?
                  It seems the euro clutch mounts with three bolts. I'm wondering if an M50 three bolt fan clutch will do the trick (PN 11527505302).
                  '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                  '87 535i - Vacuum brake conversion [SOLD]
                  '93 525iT - 5-speed swap - 320k and counting
                  '09 328xi - 6-speed
                  • sharky
                    • Jan 2005
                    • 2672
                    any 3 bolt clutch will work
                    • whysimon
                      • Jan 2007
                      • 663
                      As I've recently had to counqur this same problem I'll tell you what I did. M42 clutch fan (4 bolt) & early model E30 fan. I'm running stock 325i radiator. It's tight but it's the same setup I've been running for 5 years. Under HARD braking (stupid prius drivers) it'll touch, but I've ordered 'tranny hats' from AKG (got to love car lingo) & will report my results.
