Slave cylinder issue on m3 tranny
  • e30shmobberr
    • 1934
    Ive popped 3 slaves. is this common?
    tranny from donor m3, e30 clutch master (new), zf slave (new)
    it pops in the process of bleeding before the pedal ever gets stuff.
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    • 37833
    Then you're doing something wrong. What is your bleeding process?
    Grover Beach, California
    BimmerHeads.com
    • 328ijunkie
      • May 2007
      • 3961
      Clutch assy/fork/ stuff is put together wrong.
      Check Us out on Facebook
      Full Product Line Tuning
      • 325issguy
        • Dec 2005
        • 261
        Sounds like when I put the throwout bearing in 90 degrees rotated. Pull her and check it out.
        • e30shmobberr
          • 1934
          im doing as the bently says to. and i have used this method:
          will be pulling it this week
          • 328ijunkie
            • May 2007
            • 3961
            I never have issues with clutch bleeding. Youre all doing it wrong
