I'm doing a 24v swap but I have an issue! I have a e34 oil pan going on into my non vanos engine but their is a small braket under the piston rods! If I remove the braket from underneath will I disturb the position of the piston rod? Can someone help me out?
E34 oil pan
Originally posted by coreyw View PostNo point in breaking the bracket off, its super easy to just take the bolts out and replace them with new ones. Torque them to 20 Nm then another 50 degrees.
Yeah, I just broke it off. Twice (two different motors). Also do something to secure your oil pump nut while you're down there.1997 540i/6 - stock
1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
