Brake fluid res / Sparco strut bar
  • Fusion
    • Nov 2009
    • 3658
    My brake fluid reservoir is very close to the strut tower and up high because PO had S50.
    The reservoir won't allow me to install the Sparco shaped bar.
    What I need to know is if I can just suck out the fluid, shorten the two hoses and therefore lower the reservoir, without having to bleed air from the brakes later?
    Anyone have close-ups of their reservoir/sparco bar combo?
  • Fusion
    • Nov 2009
    • 3658
    Ah, here we go, stole this from engine bay thread.
    • Fusion
      • Nov 2009
      • 3658
      Easy question for anyone who's done it. I just wanna make sure I don't screw something up.
      • 328ijunkie
        • May 2007
        • 3961
        Just dont touch the brake pedal while youre doing it and youll be fine.
        Check Us out on Facebook
        Full Product Line Tuning
        • Fusion
          • Nov 2009
          • 3658
          Thank you.
          And is there a way to sit the reservoir directly on top of the cylinder or do they always have hoses?
            • 34827
            what's wrong with the bar you have now?
            people like to try and turn the connection at the strut tower into a moment connection. let me tell you - one extra M10 bolt and some flimsy sheet metal isn't going to do shit. a hinged bar works just as well under tension and compression, and is equally as worthless at being a moment connection. except it doesn't have the drawbacks of being more difficult to fit and work around.
            • Fusion
              • Nov 2009
              • 3658
              That silver bar is soft aluminium and very flimsy. I basically just used it to hold the harness box.
