Timing Chain Rattle
  • MaxBell
    • 1391
    Timing Chain Rattle
    Hey guys,
    I have a noise in my M50 that appears when I get into higher RPMs and on decel.
    Does anyone know if the actual rail has to be replaced? It seemed fine when I had the engine apart before it went in the car.
    Can I replace just the tensioner or is that a waste of time?
    (this thing, or do I have to do the rail as well?)
    Also: will an S50 tensioner fit a M50?
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
  • 328ijunkie
    • May 2007
    • 3961
    Depending on the sound it may be the vanos, the upper tensioner, lower or all of the above....
    Check Us out on Facebook
    Full Product Line Tuning
    • 110stx
      • Sep 2011
      • 253
      On an M42 I didn't have to deal with any vanos issues, but in replacing the timing components discovered a broken guide and significant wear that created timing chain rattle.
      STX e30
      No. 10/110 STX: 1989 325i
      DD: 1991 318is slicktop
      SHAZAM, GOMER, LOOK AHEAD.
      • MaxBell
        • 1391
        Should I just replace everything while I'm in there? Or is there a way to diagnose further?
        • 328ijunkie
          • May 2007
          • 3961
          Depends on your budget. Lower is obv really easy to replace. If that dont fix it then you usually do the vanos seals and upper at the same time.
          • MaxBell
            • 1391
            So for anyone else trying to fix a timing chain rattle that moves with RPM and your tensioners are all ok, it's your timing.
            My primary chain was off by 3 links, which threw my secondary chain off as well.
