s50 + boost or.....
  • SlowE30
    • Oct 2005
    • 64
    s50 + boost or.....
    Im thinking about swapping an s50 in my 318i. How hard is the swap? Could I be able to boost it? Around how much do rebuild kits go for? Thanks
    EDIT: or m20+stroker kit+turbo kit?
    31
    s50+AA stage 2 turbo kit
    25.81%
    8
    s50+AA supercharger kit
    19.35%
    6
    s50+ all motor rebuild
    41.94%
    13
    leave it alone
    12.90%
    4
    If your car isnt breaking, you're not driving it hard enough..
    as Carrol Shelby once said "A good driver never experiences turbo lag."
  • Addissimo
    • Mar 2004
    • 1820
    Swap is easy. you can boost anything. what are you rebuilding?
    use the search function.
    -Addis
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    • SlowE30
      • Oct 2005
      • 64
      Oh, my fault, I should have explained it a little better. I would be rebuilding whatever motor I chose. And the reason I ask if I would be able to boost it is because of clearance issues, Does the s50 motor have any swapped in the e30? TIA
      • Addissimo
        • Mar 2004
        • 1820
        m50 based motors can take quite a bit of boost. My friend is running an m52 in his e30m3 with 14 psi on a twin turbo setup. Hes making 430rwhp. The only thing hes done as far as "building" the engine is install a low comp head gasket.
        there is a 45+page thread about swapping an m50 based engine into an e30- read it... you'll learn alot.
        Its a sticky at the top of this sub forum.
        -Addis
        PS I dont know of any affordable "rebuild kits," but I'm in the process of rebuilding one myself. You can get one from bavenging, but they're $1500... include new pistons and the such, but most people don't need new pistons, and you piece what you need together alot cheaper. I'm working on a write up- when its all assembled and the project is finished, I'll put part numbers together so everybody knows whats up.
        • Brew
          • 3060
          S50 + twinscrew would be a whole lot more manageable, and keep the power within reason. All of the AA turbo kits use a bottom-mount turbo set up and would not work in the e30 without a ton of custom fabrication.
          '91 318is
          • Beej '86 325es
            • 2639
            Addis, did you ever figure out what the different color crankshaft bearings meant?
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • BahnE30
              • 1050
              i believe they're different size bearings, could be worng..... so take it with a grain of sand.
              • asubimmer
                • 6482
                turbo a m42 or heck turbo your m10. They are light, revy and fun.
                • Addissimo
                  • Mar 2004
                  • 1820
                  bingo.
                  but i'm going to suggest you just order from pelican parts or something- they sell them in a complete set, regular or oversize... its alot cheaper than buying them individually.
                  • SlowE30
                    • Oct 2005
                    • 64
                    Dont I have an M42?
                    • asubimmer
                      • 6482
                      i know... i was saying you could swap or even just turbo the m10.
                        • 34827
                        I think a built NA motor would be more overall fun.. I don't really get the point of a 500whp E30, unless you're going to use mickey T's or something..
                        • Addissimo
                          • Mar 2004
                          • 1820
                          Originally posted by SlowE30
                          Dont I have an M42?
                          yes you do... asu smokes crack or something...
                          • Q5Quint
                            • Jan 2005
                            • 725
                            I am a fan of the turbo so I vote for the turbo
                            besides, a turbo will get a lot more attention than a supercharger, though if you have unreasonably high hp it can be more dangerous (tires breaking free bc of boost)
                            I say start small and turbo your m42 and have some fun, then when your m42 dies you can sell it and its turbo kit to somebody else for some $$ and start a m50/20/s50 swap/rebuild/get ready for turbo. Then when thats done you can slap the turbo up there too for more fun, and by the end of it all you will know a shit-ton about tuning bmws.
                            • The Fast One!
                              • Jul 2005
                              • 856
                              if you are looking into a s50 swap plus turbo figure 10K easy to do it.
                              Mike Fritz
