water pump for DD stk metal / stewart ?
  • Hornung418
    • 18
    Wangan, the Plastic has been phased out by the Composite impeller.
    • singh336
      • Dec 2010
      • 211
      plastic...nooooooooooo
      • 36brua
        • 689
        Thanks for all the input from everyone !
        interesting reading on everyone combos
        My CA legal M60 swap
        The happening in our garage
        • 36brua
          • 689
          Originally posted by Wanganstyle
          plastic OEM BMW for DD. replace reasonably often with other cooling items (hoses, thermostat)
          if car is track only or boosted up or you enjoy blowing money then the stewart is great.
          I have had it and the plastic and metal oem, plastic OEM is the most engineered impeller and cannot corrode.
          plastic OEM = composite ?
          plastic understood
          why not metal ? hard on bearings ?
          I like the stewart but too much $ at the moment. too many other parts to get this put together !! LOL Thanks
          • Wanganstyle
            • 2828
            composite; plastic; same thing.
            everything plastic made by bmw is some special composite. still plastic to me
            "composite" plastic impellers for water system, plastic intake manifold "composite", "composite" plastic timing chain guides...... bmw's are made out of plastic.
            even the Front wheel bearing ball retainers on OEM BMW WBS M cars (made by FAG) have are made out of "composite" or PLASTIC. These like to crumble at laguna seca
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              interesting definition of composite...
              Originally posted by priapism
              Originally posted by shameson
              • Hornung418
                • 18
                The composite is stronger and lighter than the less-expensive metal impeller version. And it does not suffer from the problems of the early plastic design. - TMS
                They are completely different materials. And while you may argue that they are the same, for the sake of buying the right product, they are not.
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  Wangan, they are not the same as the white plastic impellers used in the past.
                  Second, ever seen what a metal impeller can do to an aluminum timing cover when it decides to explode?
                  I have, lets say its easier to clean up bits of plastic from your cooling system than it is to replace your timing cover. Although the one I witnessed was on a M3 that was heavily tracked
                  • 328ijunkie
                    • May 2007
                    • 3961
                    Graf's are junk.
                    Check Us out on Facebook
                    Full Product Line Tuning
                    • Wanganstyle
                      • 2828
                      sorry, I have never seen the old old white plastic units - was playing with STi/evo/2jz during those days.
                      I have never seen one of these old white plastic (pre composite) pumps. I'm sure they are somewhere out there though and scary
                      never seen metal impeller pump explode either, I believe you its ugly.
                      • RobertK
                        • Jun 2005
                        • 5864
                        I've had a few motors that still had the old plastic impeller and when I would go to pull the WP out most of the time the center would pull out leaving the impeller in the timing cover.
                        I was once told that the reason BMW does not use metal impellers in their cars is because of the possible damage to the timing cover (introducing water and bits of aluminum into the timing chain / oil pan).
