Well this is the solution I came up with for my setup and have run it for a couple of weeks now. Depending on the mood of the car I may get a tiny RPM stumble when the compressor engages, but it is 90% better than before as you can tell by the videos below.
I am not sure why my compressor cycles on and off in short 7 second intervals, so I will have to get the system pressure checked when I get bored.
So here is the relay diagram to ground the "activate AC" wire, which is black/gray and pin 16 for my DME, when the AC on/off switch is activated
Took me a white to find the black/gray wire in the bundle. Used a Positap to help with the connection as all it does is pierce the wire jacket to make a connection.
Test wired up the relay to the ECU. Red clip is taking 12v from AC on/off switch which is also feeding the signal to the AC on/off wire, which is violet/gray and pin 19 for my DME. Green clip is connected to ground.
Testing in the garage was perfect, no RPM stumble when the compressor cycles on and off. As I stated earlier, how the car acts when the RPMs change while driving was a bit different.
NOTE: DO NOT try cutting anything when you have marginal lighting. I was debating if I wanted to just use the Positap vs. cutting a wire and directly connecting the relay output to the DME.
I needed to snip this one strand of black nylon webbing to open up the sleeve to wrapping the DME wire bundle. After I made the cut I realized it wasn't the webbing I snipped, it was the black/gray wire. Oh well... direct connection it will be!
This is how the idle was before the idle bump solution.
When the compressor is turned on by the switch, the RPM would drop a bit, when the compressor cycles off and on I get a very noticeable stumble which shakes the car.
This is how the idle was after the relay is installed.
The stumble I get now when the compressor cycles is livable, as it doesn't make people think my car is about to stall if I am stopped at a red light.
