M52 in an 86 325 swap & tach doesn't work?
Slightly, as in- do it this way!.... No do that !... You don't need to.... Yes you do....
Working on it man... Thanks...sigpicComment
This thread is about a 24v in an early model 325. NOTHING has to be done for the tach to read proper as long as it's getting signal from the DME. If you started with a 318, then yes, IF you have a coding plug, it needs to be changed and if you have a chip in the cluster vs a coding plug, you need to change the whole cluster. Period the end without a doubt. A 6cyl tach reads 6cyls weather it be a 24v or a 12v since the spark event is happening every 120 degrees of crank rotation. A 4 cyl is reading an event every 180 degrees of crank rotation and the way your tach interprets this info is what you see the needle reading. This is why a 4cyl tach will read higher than the actual engine speed, it's thinking a signal is coming in every 180 degrees when it's actually coming in every 120.
Maybe you change the coding plug in YOUR car yesterday, but that has nothing to do with the OP's issue. The 1986 325 (e, es, i or is) tach will read the 24v RPM output, it's just the eta tach won't go past 5500rpm. The 7k tach will read just like it would with an m20 so long as it's getting signal.Last edited by ForcedFirebird; 06-04-2012, 05:13 PM.Comment
