506 dme
  • 328ijunkie
    • May 2007
    • 3961
    With some tweaking yes thats the plan. Not done yet
    Check Us out on Facebook
    Full Product Line Tuning
    • jrdeamicis
      • Nov 2008
      • 956
      Did you figure out the crank sensor yet? I can supply you with the correct PN for the swap.
      My STFT are 7% on a 2.8 tune, I would be interested to see the S52 tune on S50 and see the changes.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • evoDRichie
        • Jan 2010
        • 1743
        well i just got a s52 with a full uncut harness with no ecu what is the easist way to get it running properly obd2? what will need retro fitted if anything?
        • DesertBMW
          • Aug 2011
          • 1038
          It may be cheaper for you to run OBD2 because you got all of the obd2 stuff already. If you need an ECU then PM me, maybe I could find you one.
          • evoDRichie
            • Jan 2010
            • 1743
            That doesn't answer my question
            • Mossman
              • Apr 2006
              • 1961
              I have a stock non EWS 506 chip from a 95 M3. Put it in an EWS 506 and it deletes ews. Put it in a 413 and it works like a 95 m3 computer. I'm currently running the same setup in my OBD1 S52 with 21.5 injectors and it runs great, AFR's perfect. Sure there's a little bit of power to be gained from a custom tune but until I do 3.5" AFR and really finalize my setup I'm gonna stick with this setup. PM me if you're interested in chip. You can find 413 red's for like 60-70 now, pop this chip in and be happy on the cheap.
              • evoDRichie
                • Jan 2010
                • 1743
                i might be interested ill let u know soon any advise for what lys ahead?
                • DesertBMW
                  • Aug 2011
                  • 1038
                  I got both the OBD1 or OBD2 for your S52 swap, it all depends what way you want to go. Information about OBD1 is already on the forums. The OBD2 is not that much harder, sense the newest tunes have all the obd2 extra emissions junk deleted. But to me seems like you don't even know what else is involved in 24v swap so you should read more posts here about the swaps.
                  • evoDRichie
                    • Jan 2010
                    • 1743
                    your right i dont know much this would be my first bmw swap
                    • RobertK
                      Kicked cancer's ASS.
                      • Jun 2005
                      • 5864
                      I have a good 506 DME I would gladly trade you for your OBDII S52 ECU.
                      • evoDRichie
                        • Jan 2010
                        • 1743
                        i wish .. but it did not come with any DME sorry buddy
                        • 328ijunkie
                          • May 2007
                          • 3961
                          Run it OBD2. Everyone really needs to stop going backwards.
