Rubber gaskets? What a joke.
  • lolcantturn
    • 4588
    Changed my oil filter housing to a freshly cleaned one. Cleaned both mating surfaces (the block and the housing). Brand new gasket. Tightened all the bolts fairly tight, put back the alternator, turned on the car, huge HUGE puddle of oil under the car, at least a quart. Fuck. Let's try this again.
    Took the oil filter housing off, which only lead another large god damn amount of oil to spill. Cleaned both surfaces, this time RTV'd both surfaces with black silicon "oil resistance" crap.
    Put all the bolts back on, alternator, turned on the engine. Same amount of oil spewing out.
    Fuck man I'm done.
    /rant
    Originally posted by TSI
    OEM+
  • DesertBMW
    • Aug 2011
    • 1036
    Oil housings have the dowel pin guides, some of these get stuck in the block or housing, and if you are putting another housing that housing may already have dowel pin in the same location and that will prevent the housing bolting on properly.
    • lolcantturn
      • 4588
      Though I did not double check if my new oil housing has the dowel pin stuck on it, I do have a dowel pin on the block that the housing pressed fairly easy on....so I'm assuming I don't have a dowel pin stuck on my current housing.unless there is more than one dowel pin?
      OEM+
      • DesertBMW
        • Aug 2011
        • 1036
        there are 2, tow it to the shop, let another eye take a look at it
        • masduro
          • Aug 2011
          • 221
          R3V'd both surfaces with black silicon.
          • hwy84
            • Aug 2009
            • 190
            ^ Ha!
            Current:
            1991 325i Sedan - S50 Swap
            1988 325i Cabrio
            Past:
            1991 M3
            1991 318is
            1985 325e
            • 328ijunkie
              • May 2007
              • 3961
              Never had one leak after replacing it :dunno
              RTV wont work there.
              Check Us out on Facebook
              Full Product Line Tuning
              • m3boost
                • Oct 2005
                • 110
                copper sprays works for me all the time
                88 e30/s50 gt35r turbo m3
                96 gt4094r turbo m3
                452 rwhp, 455 rwtq at 14 psi 91 octane
                681 rwhp, 684 rwtq at 25 psi E65
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  Lolcantwrench
                  '89 Alpine S52 with goodies
                  • bernzpeed
                    • 3917
                    There is an o-ring that goes in the housing. you do know that, right?
                    Sent from my SPH-D710 using Tapatalk 2
                    89 E30 S52
                    Transaction Feedback.
                    • lolcantturn
                      • 4588
                      There is no "o-ring" ?
                      I'm just going to go with the dowel idea, maybe there are two dowels pressing against each other.
                      OEM+
                      • RobertK
                        Kicked cancer's ASS.
                        • Jun 2005
                        • 5864
                        Check it for cracks. I've seen these things crack and wreak havoc. There are also usually one or two spots capped off with a circlip and what looks like a metal cover. I've seen those leak too if the oring behind them goes bad.
                        • RobertC
                          • Dec 2010
                          • 127
                          There are a couple different housings.
                          Exactly.
                          The early (M50) housings (92-94'?) had 2 plugs in the side similar to that of the M20 filter housing plug.
                          I ran into this once before myself. I pulled it apart, cleaned it all up and bolted it back together only to have it leak just like before.
                          You have 2 choices, go with a later housing that does not have to 2 side plugs or you can reseal the two plugs. They are about the size of a quarter and have lock clips in them. There are no specific service parts listed for them but I did find the O-rings that fit perfectly.
                          11-42-1-174-764 X 2
                          Good Luck with it.
                          www.facebook.com/E30motorwerks
                          • dsobering47
                            • Oct 2007
                            • 697
                            Pro-tip: Loosen the oil filter cap and let the oil drain for a minute to help lessen the amount of spilled oil when you remove the filter housing.
                            • lolcantturn
                              • 4588
                              Exactly.
                              11-42-1-174-764 X 2
                              Good Luck with it.
                              Can you show me a closer picture of these circlips? I'm having trouble finding them on the housing.
                              OEM+
