Pardon my ignorance, but what's the go with oil coolers in twin cam 6cyl E30s? Doing a bit of searching around, I can't even work out if E36s ran oil coolers. Also, in all my searching around for the twin cam conversion I don't recall reading anything about it. Perhaps an oil cool isn't necessary, but my 325is already has one...so I may as well use it if possible.
oil coolers and M50/52s
This topic is closed.
It will cost you alot of money, and unless you're building a high hp engine, you probably won't need it.
www.vacmotorsports.com has a variety of oil coolers compatible with m/s5x engines.
Doing something M50 related? -> http://www.addissimo.com
On Myspace? ->http://groups.myspace.com/r3vlimited
BF2142 SN = BillyGoose
Funny you should ask. I've been told you have to have a euro oil filter housing but if you look at the M50 housing it has a flat bolt on the side of it that does nothing. I think you could pretty easily make it work but you want to make sure the oil flow is right.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
"I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
the euro oil filter housing and the s54 housing is the same part number. you need to tap one outlet for the vanos unit but its straightforward. just order an s54 casting and go with a mocal or earls cooler and some braided lines. i think i have 600 into mine give or take. im running an earls 25 row. its definatley needed on the track. i was pushing 280+ degrees without it and even under the most sever conditions ive never went above 250 on the track after installing it.
ps, im not sure the place i have my sender is the most accurate but regardless its dropped 30 degrees with the cooler
i dont know enough about the stock casting to comment but it sounds risky. you also have to think about the thermostat built into the euro/s54 casting to keep you from blowing your cooler when the oils cold and thicker. i think if it were that easy guys would have been doing it before us.Originally posted by joshhFunny you should ask. I've been told you have to have a euro oil filter housing but if you look at the M50 housing it has a flat bolt on the side of it that does nothing. I think you could pretty easily make it work but you want to make sure the oil flow is right.
Or maybe no one has thought of it.....it's possible.
Your not going to blow the cooler. The only time coolers blow is when the oil can't get through the filter in time and that would not be a problem here.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
YOU DO IT ON YOUR MOTOR AND LET US KNOW. YOU NEED AN IN AND AN OUT. AND OIL COOLERS MOST CERTAINLY BLOW. GOOD ONES DO ANYWAY. THEY ARE THIN FOR A REASON. TRY REVVING 7200 WITH NO OIL THERMOSTAT WITH 20/50W BEFORE THE OILS WARM. THE TUBE AND FIN 9 DOLLAR COOLERS MAY BE ABLE TO TAKE THAT BUT A MOCAL OR EARLS WONT. THATS WHY THERES A BUILT IN THERMOSTATOriginally posted by joshhOr maybe no one has thought of it.....it's possible.
You obviously missed part of my point. A thermostat allows the oil to bypass the filter or even the cooler all together so the cooler doesn't blow. Thus my not getting threw the filter comment.
The "good ones blow"....then their no good. Thin is not really that big of a deal. Just the fact that you have an oil cooler at all is more important then if it's thin.
And yes they do blow if you don't think about what your doing. Or you made a mistake.
You can add an aftermarket thermostat right after the filter housing so pressure doesn't build and the oil can warm before going to the cooler.
I probably will do it unless I find it simply wont work for one reason or another. But as of now I have yet to see anyone on the net say why you can do it with the US version.
And why do you need to rev to 7200 before the oil is warm? That's just common sense.Last edited by joshh; 11-14-2005, 10:22 AM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Euro E36 M3 oil filter housing.....11427833240.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
josh is on to something... this idea has been floating through my head for quite some time now, I've just been too busy with the other aspects of my engine to put too much thought into it.
And yeah.... seriously... who the fuck revs their engine to 7200 before it is warm, espceially running thick ass oil? Talk about fucking your lifters man.
I think it's at least worth looking into further.
12 oz spray and 8 oz Green oil to clean and recharge your filter Keep your Active Autowerke / Green High Performance Air Filter in perfect condition with the specially formulated Recharge Oil (8 oz.) and Cleaner Spray (12 oz.). Both are sold together as a complete Cleaning KIT. The recharge oil is designed to trap the
This kit is way over priced but there are a couple of good pics of the euro casing.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Yes but there is a valve (thermostat) that cuts it off from the pressure of the rest of the oil.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
