i bought a 91 525i automatic m50 it came with the wiring harness... but it is the e34 automatic wiring harness ....i need to knoww what ecu i need to use and also what wires i need to remove..... any info will be appriciated
e34 wireing harness issues
Use the 413 DME. Red label if you can get it.
You can leave the automatic harness connected or open the harness up and trace back each wire that connects to the automatic stuff and carefully remove them 1 by 1. Its not very hard to do.91 m3 -
Ditch the e34 harness. The routing is all messed up and its not long enough to route and look good.
Get a normal e36 M50 harness.Tenured Automotive Service Professional - Avid BMW Enthusiast
https://mtechniqueabs.com/Comment
Your harness will work, but like jordan said it is to short to mount your ecu in the stock e30 location. The plug that connects the harness to the fuse box is also on the wrong side so you will need to run wires across. If none of this bothers you, you should be fine. I think the harnesses off of the manuel cars are wired for automatics but the wires do not have connectors on them and are tucked into the harness case. I might be wrong, thats just what I have gathered from looking at my harness. Good LuckComment
you dont want the 413 for that engine... if its a 91, its non vanos... i belive thats the 403, dont quote me on that, but find out for sure which ecu goes to the non-vanos motor. I'd just stick to the harness you have, no point in wasting money. If you have wiring ability, you can cut the auto connector off very carefully. you have to trace everywire to and from the dme connector... it'll take you a few hours for sure.
-Addis
Doing something M50 related? -> http://www.addissimo.com
On Myspace? ->http://groups.myspace.com/r3vlimited
BF2142 SN = BillyGooseComment
hey rs4pro3...i will need those printouts those wood help out alot.......o yea my friend robert road with you through deals gap......send me a pm with a phone number or i could give u mine......i think the 403 or 402 maybe the 401...i got a line on a e36 harness i know a feww connects around here so my e34 might b 4 sale or tradeComment
