24v tune: 91 vs. 93 Oct
  • Rugbyfan
    • Jun 2011
    • 286
    I'm getting ready to pull the trigger on a new OBD-1 chip from TRM. I always fill up with 93 Octane, and really don't perceive getting 93 to really be an issue. I live in Savannah where it get's quite hot, and it is my daily driver. I'm not really interested in squeezing every possible amount of power from my motor. That being said:
    Is the difference in tunes (TRM or otherwise) for 91 Oct and 93 Octane noticeable at all?
    Would getting the 91 tune and still filling up with 93 be "safer" than a 93 tune?
    can OBD-1 still retard timing effectively if a 93 tune knocks due to extreme heat or a batch of bad gas?
    R3V's recommendations?
    "Broke into the wrong God damn rec room, didn't ya you bastard!"
  • 328ijunkie
    • May 2007
    • 3961
    Save money, go OBD2 ;)
    Check Us out on Facebook
    Full Product Line Tuning
    • Rugbyfan
      • Jun 2011
      • 286
      hahah saw that coming. Ultimately, I will.
      • DesertBMW
        • Aug 2011
        • 1043
        To answer your questions if you live in hot climate stay with bone stock tune. It is already tuned for 93(recommended) and 91(minimum)
        TRM tune will be more aggressive and if there is knock, timing will be retarded and make the engine run worse
        • Rugbyfan
          • Jun 2011
          • 286
          I actually currently have an old TMS tune. I have only actually heard knock one time, and it was hot as balls, and I was driving it very very hard. I also will be relocating up north in the not too distant future, so I suppose short term heat is not a real concern.
