Coolant Hose Kit?
  • coreyw
    • Jul 2010
    • 368
    Coolant Hose Kit?
    Would it be a good idea to order this kit? Or will I only need a few of these for the S52 swap?
    http://www.fcpeuro.com/products/bmw-...s52-m52hosekit
    Thanks.
    S52 Swap
    Shtuff For Sale
  • eurosport22
    • 210
    i used a good amount of e30 hoses cut to fir and even a few random 90 degree ones from auto zone. if i remember correctly i had quite a few brand new e36 hoses left over that i ended up not using. kinda pissed me off. not i was using the m42 rad. so i may have a different application than you
    • hwy84
      • Aug 2009
      • 190
      Thanks.
      If you plan on replacing all the hoses anyhow (which you likely should) - then you'll end up using most of those, possibly all of them, depending on your radiator/expansion tank setup, and whether or not you plan to run your heater (becuz streetcar).
      In most cases the lower radiator hose is a bit too long for the e30 fitment. I ran mine without cutting it, but it rubs against the front of the motor near the timing chain tensioner, and I need to cut it shorter so that it clears.
      Current:
      1991 325i Sedan - S50 Swap
      1988 325i Cabrio
      Past:
      1991 M3
      1991 318is
      1985 325e
      • Cyrix2k
        • 593
        I'd only order the e36 upper & lower radiator hoses. Get the rest of the hoses at your local autoparts store as they're either straight shots or custom.
        1997 540i/6 - stock
        1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
        1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
        • coreyw
          • Jul 2010
          • 368
          Okay cool, thanks everyone!
          S52 Swap
          Shtuff For Sale
