Oil blowing onto block
  • 318 slammin
    • Apr 2012
    • 20
    After a half hour of driveing my car blows oil onto the block just above the pan I replaced the gasket with a decent ammount of permitex super black let sit overnight last night my car was leaking on the block above the pan on the drivers side but really high up the block so I'm not sure if it's the oil pan seal or not I have an obd1 m50 venos
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Having a hard time visualizing what you're talking about.
    Do you have a leak at the back of your engine that runs down the block onto the oil pan?
    If this is the case check your valve cover to be sure the half moons that seal the cam access in the back of the head are seated correctly.
    If its leaking at the front of the block then check the oil filter housing.
    • butters
      • 1202
      Originally posted by 318 slammin
      After a half hour of driveing, my car blows oil onto the block just above the pan.
      I replaced the gasket with a decent ammount of permitex super black, let sit overnight.
      last night my car was leaking on the block, above the pan, on the drivers side, but really high up the block. I'm not sure if it's the oil pan seal or not.
      sorry, I could barely read it without punctuation.
      if it's leaking on the block, above the pan, I'm not sure what would bring you to the conclusion that it's the pan gasket. gravity tends to pull down, not up. there are a bunch of places to check for a leak - vanos line and cam position sensor come to my mind.
      • 318 slammin
        • Apr 2012
        • 20
        It's leaking around where my driverside motor mount is but it's wet a decent way up my block
        • 318 slammin
          • Apr 2012
          • 20
          Before I changed the gasket it was soaked all over my pan blowing on my exhaust and smoking a ton now it's just the drivers side and I don't think getting on my exhaust it smokes while I'm stopped
          • 318 slammin
            • Apr 2012
            • 20
            Update on my issue, it is leaking from somewhere on the top middle of my block on the drivers side. Could it be a sensor?
            • surebimmer
              • Jan 2004
              • 978
              Sounds to me like oil filter housing gasket. Also check your vanos line.
              See this link http://www.bmwtips.com/tipsntricks/oil/housing.htm
              • accident
                • 7303
                Plus one for the VANOS line. I changed my friend's camshaft sensor and ended up loosening it by accident. Car was pissing oil everywhere, eventually I figured out that it was leaking from there.
                Moral of this story?
                • 318 slammin
                  • Apr 2012
                  • 20
                  It doesn't seem wet near my filter housing, but also it's kinda in a shitty spot to eyeball. would the venos line or oil filter housing gasket cause it to leak at the middle of my block? I might just replace both incase but I am wondering if if could be anything else near the middle of the block
                  • scottinAZ
                    • Dec 2009
                    • 1312
                    lots of things in that area, vanos line, oil pressure sensor, oil filter housing, all can cause a wet spot in the area you are describing.
                    I saved 15% on my Bimmer parts by switching to ...
                    • RobertK
                      • Jun 2005
                      • 5864
                      You're gonna have to get dirty and pull some stuff out of the way to properly diagnose the issue. But most likely the VANOS oil hose or oil filter housing gasket is toast.
                      • M3PO
                        • May 2012
                        • 537
                        It could be the plugs on the filter housing or the filter housing itself.
                        • Roysneon
                          • 4505
                          You have a great screen name.
                          Originally posted by mbonanni
                          I am a pursit now.
                          • M3PO
                            • May 2012
                            • 537
                            Lol thanks!
                            Good luck/free bump for OP!
                            • 318 slammin
                              • Apr 2012
                              • 20
                              I Drove the car yesterday to make it leak so that I could findwhere it's coming out of. it started leaking then just stopped? But still leaks after driving a long distance but will stop leaking after 5 min, it's wierd but I'm trying to narrow down wat I should start looking for. I would think if the filter housing was leaking it woulld be all the time that it leaks correct? So I'm thinking maybe vanos line? Because vanos is not engaged at idle?
